Re: IMarker - problem view and editor [message #331972 is a reply to message #331945] |
Tue, 30 September 2008 19:36 |
John Rodriguez Messages: 8 Registered: July 2009 |
Junior Member |
Thanks for your help.
Can getting the resource be done with static calls to get the resource (I
don't have the IRresource when I am trying to make a marker because I have
only a file name path that is given back from the Lua interpreter).
For example using:
ResourcesPlugin.getWorkspace() ...
In my line break point code, I am given a IWorkBechPart, from which I can
get my text editor:
public void toggleLineBreakpoints(IWorkbenchPart part, ISelection
selection) throws CoreException {
ITextEditor textEditor = getEditor(part);
IResource resource = (IResource)
editorPart.getEditorInput().getAdapter(IResource.class);
But I believe you are referring to the file resource that I have
interpreted to find the Lua syntax error in the editor, correct?
Daniel Megert wrote:
> John Rodriguez wrote:
>> I have written a new implementation of a debugger and editor for Lua.
>> I was trying to set an "Error" IMarker in the editor.
>> I set an IMarker and the marker shows up in the "Problems view" but
>> not in the editor. How can I get it to appear in both?
>> Here is the code I set the marker with.
>> IWorkspaceRunnable editorMarker = new IWorkspaceRunnable() {
>> public void run(IProgressMonitor monitor) throws CoreException {
>> IMarker marker = ResourcesPlugin.getWorkspace().getRoot().
> This is wrong. You need to create the marker on the resource that's
> shown in the editor.
> Dani
>> createMarker(IMarker.PROBLEM);
>> marker.setAttribute(IMarker.MESSAGE, msg);
>> marker.setAttribute(IMarker.LINE_NUMBER, lineNumber);
>> marker.setAttribute(IMarker.TRANSIENT, true);
>> marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_ERROR);
>> try {
>> ResourcesPlugin.getWorkspace().run(editorMarker, null);
>> } catch (CoreException e) {
>> System.err.println("Some error set marker: " + e);
Re: IMarker - problem view and editor [message #331992 is a reply to message #331972] |
Wed, 01 October 2008 10:54 |
Dani Megert Messages: 3802 Registered: July 2009 |
> (I don't have the IRresource when I am trying to make a marker because
> I have only a file name path that is given back from the Lua
> interpreter).
> For example using:
> can get my text editor:
Right. At the point you add the marker you need to resolve the correct
resource otherwise it won't show up in the editor.
Dani
>>> IMarker marker =
>> Dani
>>> try {
FUDForum. Page generated in 3.77355 seconds
