Home » Eclipse Projects » Eclipse Platform » Default configuration for dev environment
Default configuration for dev environment [message #331910] Sun, 28 September 2008 14:44 Go to next message
Hi all,
I'm responsible of providing the Eclipse development environment in my
company.
We're using a lot of different plugins (from eclipse.org or not), most of
the time, each plugin config has to be the same in every developer
workspaces.
From my understanding, to automatically initialize a given workspace with
default configuration for many plugins, I should define files inside the
configurationArea/.settings/some.plugin.fqn
So, some questions:
* Am I right saying this about the .settings directory?
* Is this the right/recommended way to do it?
* How to know the right name for each file? I guess it's something like
the bundle-symbolicname of the plugin I want to be configured. Could I
just take the values exported using "Export Preferences"?
Thanks a lot for any hints.
Cheers.
PS : if you think there's a better newsgroup for this question, please let
me know.
Re: Default configuration for dev environment [message #332009 is a reply to message #331910] Wed, 01 October 2008 09:41 Go to previous message
Baptiste MATHUS wrote:
> Hi all,
> company. We're using a lot of different plugins (from eclipse.org or
> not), most of the time, each plugin config has to be the same in every
> developer workspaces.
> with default configuration for many plugins, I should define files
> inside the configurationArea/.settings/some.plugin.fqn
AFAIK this may or may not work, depending on if the specific code that
needs the preferences searches the config scope or not (many do not).
The 2 ways to do that at the moment are 1) export all of the preferences
and then import them into each new workspace or 2) copy all of the
*.prefs file from the
<workspace>/.metadata/.plugins/org.eclipse.core.runtime/.settings/ into
(or as you create) each new workspace.
Some preferences (like compiler preferences) can be set per project,
which means they can be saved in your source control along with the
project files.
PW
Paul Webster
Previous Topic:Question about extension-point org.eclipse.ui ViewActions
Next Topic:ActiveEditorId Expression
Current Time: Sun Apr 27 02:09:21 EDT 2025
Powered by FUDForum. Page generated in 0.03389 seconds
