Re: Updating and/or re-intalling Eclipse 3.4.1 [message #331875] |
Fri, 26 September 2008 05:13 |
Originally posted by: codeslave.ca.ibm.com
This is a question for the platform and Equinox.p2 folks. I've copied
this there.
BTW, unpacking Eclipse version Y on top of Eclipse version X is NOT
recommended because, as you see, it tends to disable installed features.
Jorge Dieguez wrote:
> Hi there,
> I wanted to update to 3.4.1 (RCP/pluging developer package)then try to
> just Help->Software updates->update but Eclipse seemed hung up.
> Then I tried to just install 3.4.1 directly (on top of 3.4 directory
> structure) by unzipping eclipse-rcp-ganymede-SR1-win32.zip (RCP/pluging
> developer package)
> When launching eclipse, it does not get to the point of asking which
> workspace I want to open. Instead it gives up launching and screens:
> An error has occurred. see the log file
> \eclipse\configuration\122....log (file content is bellow at the end)
> I have installed 3.4.1 in an empty directory and it launches fine. But
> -of course- I have to re-install swt/JFace plugins that I had installed
> before in 3.4 directory.
> I have also notice that .metadata (with MyLyn files) are not presented
> in the new installation. If I recalled rightly it came originally with
> the package.
> Many thanks in advance.
> Jorge
> java.lang.RuntimeException: No application id has been found.
> at
> org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
> at
> org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> !ENTRY org.eclipse.osgi 2 0 2008-09-25 18:04:08.531
> !MESSAGE One or more bundles are not resolved because the following root
> constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-25 18:04:08.531
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.ui_2.0.0.v20080916-13 01.jar was
> not resolved.
> !SUBENTRY 2 org.eclipse.ecf.ui 2 0 2008-09-25 18:04:08.531
> !MESSAGE Missing required bundle org.eclipse.ecf.presence_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.ecf.sharedobject_0.0.0.
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.provider.discovery_2. 0.0.v20080916-1301.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.discovery 2 0 2008-09-25 18:04:08.531
> !MESSAGE Missing required bundle org.eclipse.ecf.discovery_0.0.0.
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.provider.bittorrent.u i_0.2.0.v20080916-1301.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.bittorrent.ui 2 0 2008-09-25
> 18:04:08.531
> !MESSAGE Missing required bundle org.eclipse.ecf.filetransfer.ui_0.0.0.
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.presence.bot_1.2.0.v2 0080916-1301.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.presence.bot 2 0 2008-09-25 18:04:08.531
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.provider.xmpp.ui_2.0. 0.v20080916-1301.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.xmpp.ui 2 0 2008-09-25 18:04:08.531
> !MESSAGE Missing required bundle org.eclipse.ecf.provider.xmpp_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.ecf.presence.ui_0.0.0.
> !MESSAGE Missing required bundle org.eclipse.ecf.provider_0.0.0.
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.provider.msn_1.2.0.v2 0080916-1301.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.msn 2 0 2008-09-25 18:04:08.531
> !MESSAGE Missing required bundle org.eclipse.ecf.protocol.msn_0.0.0.
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.discovery.ui_2.0.0.v2 0080916-1301.jar
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.discovery.ui 2 0 2008-09-25 18:04:08.531
> !MESSAGE Missing required bundle org.eclipse.ecf.remoteservice_0.0.0.
> !ENTRY org.eclipse.osgi 2 0 2008-09-25 18:04:08.546
> !MESSAGE The following is a complete list of bundles which are not
> resolved, see the prior log entry for the root cause if it exists:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-25 18:04:08.546
> !MESSAGE Bundle
> [132] was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.discovery.ui 2 0 2008-09-25 18:04:08.546
> !MESSAGE Bundle
> [134] was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.presence.bot 2 0 2008-09-25 18:04:08.546
> !MESSAGE Bundle
> [135] was not resolved.
> 18:04:08.546
> !MESSAGE Missing required bundle org.eclipse.ecf.ui_0.0.0.
> 18:04:08.546
> !MESSAGE Bundle
> [136] was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.discovery 2 0 2008-09-25 18:04:08.546
> !MESSAGE Bundle
> [137] was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.msn 2 0 2008-09-25 18:04:08.546
> !MESSAGE Bundle
> [138] was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.provider.xmpp.ui 2 0 2008-09-25 18:04:08.546
> !MESSAGE Bundle
> reference:file:plugins\org.eclipse.ecf.ui_2.0.0.v20080916-13 01.jar [140]
> was not resolved.
> !SUBENTRY 2 org.eclipse.ecf.ui 2 0 2008-09-25 18:04:08.546
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.02943 seconds
