Home » Eclipse Projects » Eclipse Platform » Adding a view into a perspective without opening the perspective.
Adding a view into a perspective without opening the perspective. [message #331826] Wed, 24 September 2008 03:23 Go to next message
I want to add a view into a perspective. The view has the 'allowMultiple'
flag set and is opened multiple time within different perspectives.
At the moment I open the view using a IWorkbenchPage received by calling
showPerspective().
IWorkbenchPage page =
PlatformUI.getWorkbench().showPerspective(processor.getId(),
PlatformUI.getWorkbench().getActiveWorkbenchWindow());
TaskView processorView = (TaskView)page.showView(TaskView.ID, secondaryId,
IWorkbenchPage.VIEW_CREATE);
This approach has the drawback that the perspective into which a view is
placed has to be shown. I would prefer adding a view 'silently' into a
perspective without having to show the perspective at the same time.
Is this possible?
Jan
Re: Adding a view into a perspective without opening the perspective. [message #331858 is a reply to message #331826] Thu, 25 September 2008 09:53 Go to previous messageGo to next message
Jan Kohnert wrote:
> Hello,
> 'allowMultiple' flag set and is opened multiple time within different
> perspectives.
> showPerspective().
> secondaryId, IWorkbenchPage.VIEW_CREATE);
> Is this possible?
I suppose you could do it declaratively in plugin.xml instead of via
Java code. Use the org.eclipse.ui.perspectiveExtensions extension point.
Hope this helps,
Eric
Re: Adding a view into a perspective without opening the perspective. [message #331862 is a reply to message #331858] Thu, 25 September 2008 10:42 Go to previous messageGo to next message
Eric,
I don'nt think that it is possible doing it declaratively. The
perspectives are all cloned perspectives. The cloned perspectives Id's are
all dependant on a processors (a model class )id. A processors id is
unfortunately not predictable. So it us impossible to add such a
perspective id into any extension point. :(
Jan
Re: Adding a view into a perspective without opening the perspective. [message #331867 is a reply to message #331826] Thu, 25 September 2008 14:27 Go to previous message
No, only the active perspective can be updated with views. There's no
way to address view.X into open.inactive.perspective.Y
PW
Paul Webster
Previous Topic:Override or extend default resource delete action
Next Topic:Eclipse 3.4 on Solaris 10 sparc
Current Time: Thu Oct 16 08:16:09 EDT 2025
Powered by FUDForum. Page generated in 0.03914 seconds
