Home » Eclipse Projects » Eclipse Platform » Eclipse 3.5 Plan?
Eclipse 3.5 Plan? [message #331823] Tue, 23 September 2008 23:36 Go to next message
Colin Sharples is currently offline Colin SharplesFriend
Member
I was trying to find the Eclipse 3.5 plan, but it doesn't seem to exist.
This is a bit odd considering there are two milestone builds out.
Is the plan secret? Delayed? Making it up on the fly?
Colin Sharples
CTG Games Ltd
Wellington, New Zealand
Re: Eclipse 3.5 Plan? [message #331824 is a reply to message #331823] Tue, 23 September 2008 23:49 Go to previous messageGo to next message
--------------070308030503080408020901
Colin,
It does seem a little odd that we're two milestones into the plan
without a public published plan. The EMO's deadlines require that the
projects provide a standard format plan.xml by the end of September.
The Planning Council (and I suppose the Requirements Council) will take
these plan.xml documents as input to create a consolidated plan for
Eclipse as a whole. In theory, from this page
http://www.eclipse.org/projects/listofprojects.php
you should be able to click on any project, find the "Project Plan"
section for it, and then click on the plan link to see what's planned...
> exist. This is a bit odd considering there are two milestone builds out.
<html>
<head>
http-equiv="Content-Type">
</head>
Colin,<br>
<br>
Ed Merks
Re: Eclipse 3.5 Plan? [message #331825 is a reply to message #331823] Wed, 24 September 2008 00:21 Go to previous messageGo to next message
The planning process is finishing up.
Here is an informal list of plans:
http://wiki.eclipse.org/Eclipse/Galileo_Plan
~ Chris
Re: Eclipse 3.5 Plan? [message #331842 is a reply to message #331825] Wed, 24 September 2008 19:24 Go to previous messageGo to next message
John J. Barton is currently offline John J. BartonFriend
> Cheers,
> ~ Chris
Where would improvements to Window > Pref > General > WebBrowser
function live?
jjb
Re: Eclipse 3.5 Plan? [message #331843 is a reply to message #331842] Wed, 24 September 2008 19:29 Go to previous messageGo to next message
> function live?
I would assume it would be in the Platform UI or the SWT plans.
I suggest you file bugs first otherwise it won't make it on the plan.
~ Chris
Re: Eclipse 3.5 Plan? [message #331847 is a reply to message #331843] Thu, 25 September 2008 00:22 Go to previous message
>> function live?
> Cheers,
> ~ Chris
Thanks for the hints Chris:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248516
John
Previous Topic:EFS again... Metadata
Next Topic:Close view programatically
Current Time: Thu Aug 29 21:03:04 GMT 2024
Powered by FUDForum. Page generated in 0.03100 seconds
