Home » Eclipse Projects » Eclipse Platform » Override or extend default resource delete action
Override or extend default resource delete action [message #331821] Tue, 23 September 2008 17:05 Go to next message
Is there a way to override or extend the default action for deleting a
resource from the Project Explorer?
Basically I want to be able to attempt to delete a file, and in addition
to the confirmation message 'Are you sure you want to delete xxxx?', I
want it to fire up an additional dialog warning the user in the case of
the file being referenced in a GMF diagram - something like 'File xxxx is
referenced in file yyyy. Are you sure you want to delete xxxx?'.
I've tried looking at seeing if this can be done via a resource listener,
but the event reported by IResourceDelta.REMOVED it seems is already too
late, and I don't see a way of intercepting the delete action before the
delete happens.
Any help will be greatly appreciated.
-David
Re: Override or extend default resource delete action [message #331866 is a reply to message #331821] Thu, 25 September 2008 14:25 Go to previous message
On top of the delete resource event itself, in 3.4 even the IDE delete
action invokes the LTK refactoring support. deleteParticipants can be
added.
See LTK in the Platform Plug-in Developers Guide, for example
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/reference/extension-points/org_eclipse_lt k_core_refactoring_deleteParticipants.html
PW
Paul Webster
Previous Topic:Refreshing External Folders in Ganymede
Next Topic:Adding a view into a perspective without opening the perspective.
Current Time: Fri Apr 11 23:02:11 EDT 2025
Powered by FUDForum. Page generated in 0.02964 seconds
