Home » Eclipse Projects » Eclipse Platform » Eclipse 3.4/3.5 M2 build issue
Eclipse 3.4/3.5 M2 build issue [message #331794] Mon, 22 September 2008 13:11 Go to next message
Hi ,
3.4 & 3.5 M2 builds are failing on compilation . Looks like it's not able
to pickup the rt.jar classpath. Many people has quried about this. But
there is no solution given for this. Help please !!!.
http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 657.html
init:
@dot:
[mkdir] Created dir:
/store/eclipse/3_4_source/plugins/org.eclipse.equinox.l
auncher/temp.folder/@dot.bin
[javac] Compiling 5 source files to
lipse.equinox.launcher/temp.folder/@dot.bin
[javac] ----------
[javac] 1. ERROR in
/store/eclipse/3_4_source/plugins/org.eclipse.equinox.la
uncher/src/org/eclipse/core/launcher/Main.java (at line 1)
[javac]
[javac] ^
[javac] The type java.lang.Object cannot be resolved. It is indirectly
refer
enced from required .class files
[javac] ----------
[javac] 2. ERROR in
uncher/src/org/eclipse/core/launcher/Main.java (at line 23)
[javac] public class Main {
[javac] 259. ERROR in
/store/eclipse/3_4_source/plugins/org.eclipse.equinox.launch er/src/org/eclipse/equinox/launcher/WebStartMain.java
(at line 249)
[javac] StringBuffer finalBundleList = new
StringBuffer(allBundles.size() * 30);
[javac] ^^^^^^^^^^^^
[javac] StringBuffer cannot be resolved to a type
[javac] ----------
[javac] 259 problems (259 errors)
BUILD FAILED
/store/eclipse/3_4_source/build.xml:68: The following error occurred while
executing this line:
/store/eclipse/3_4_source/build.xml:8: The following error occurred while
/store/eclipse/3_4_source/features/org.eclipse.sdk/build.xml :39: The
following error occurred while executing this line:
/store/eclipse/3_4_source/features/org.eclipse.sdk/build.xml :17: The
/store/eclipse/3_4_source/features/org.eclipse.platform/buil d.xml:341: The
/store/eclipse/3_4_source/features/org.eclipse.platform/buil d.xml:327: The
/store/eclipse/3_4_source/features/org.eclipse.help/build.xm l:95: The
/store/eclipse/3_4_source/features/org.eclipse.help/build.xm l:82: The
/store/eclipse/3_4_source/features/org.eclipse.rcp/build.xml :314: The
/store/eclipse/3_4_source/features/org.eclipse.rcp/build.xml :15: The
/store/eclipse/3_4_source/plugins/org.eclipse.equinox.launch er/build.xml:137:
The following error occurred while executing this line:
/store/eclipse/3_4_source/plugins/org.eclipse.equinox.launch er/build.xml:95:
Compile failed; see the compiler error output for details.
Total time: 14 seconds
Re: Eclipse 3.4/3.5 M2 build issue [message #331838 is a reply to message #331794] Wed, 24 September 2008 14:10 Go to previous message
The org.eclipse.equinox.launcher bundle does not depend on anything
except the bootclasspath.
Therefore, if you are getting compile errors, then you did not set up
the bootclasspath properly. In your link, notice the "incorrect
classpath" errors that make it obvious that this is the case.
You specified
J2SE-1.4="C:\\Program Files\\Java\\j2sdk1.4.2_17\\jre\\lib"
J2SE-1.5="C:\\Program Files\\Java\\jdk1.5.0_16\\jre\\lib"
JavaSE-1.6="C:\\Program Files\\Java\\jdk1.6.0_07\\jre\\lib"
These are not valid classpaths, you need to list the actual jars you
want to compile against. I'm not sure about the space in the path, the
quotes may be good enough for that. Try
J2SE-1.4="C:\\Program Files\\Java\\j2sdk1.4.2_17\\jre\\lib\\rt.jar"
or maybe escape the space. Additional jars can be added as well:
J2SE-1.4=C:/Program\ Files/Java/j2sdk1.4.2_17/jre/lib/rt.jar;C:/Program\
Files/Java/j2sdk1.4.2_17/jre/lib/jsse.jar
Also, in your link,
Gowri wrote:
> Hi ,
> able to pickup the rt.jar classpath. Many people has quried about this.
> But there is no solution given for this. Help please !!!.
> init:
> @dot:
> [javac] ----------
> [javac] 1. ERROR in
> [javac]
> [javac] ^
> refer
> [javac] ----------
> [javac] 2. ERROR in
> [javac] public class Main { ..
> (at line 249)
> [javac] ----------
> BUILD FAILED
Previous Topic:Text: Adjacent partitions of same content type not merged?
Next Topic:Two config.ini being generated
Current Time: Thu Oct 30 04:07:21 EDT 2025
Powered by FUDForum. Page generated in 0.04530 seconds
