Home » Eclipse Projects » Eclipse Platform » File hiding in perspectives
File hiding in perspectives [message #331776] |
Mon, 22 September 2008 07:14 |
Originally posted by: massimiliano.fanciulli.intecs.it
Hi All,
i'm here to ask you the following, since i haven't found any answer in
the documentation. I'm developing a plugin extension for eclipse 3.2 and
i have added some new perspectives. No problem with that except for the
fact that, when enabled, files with filename that start with a dot are
not hidden by default. Those files are not visible if, for example, i
activate the Java perspective. Can you tell me how to enable/disable
this behaviour programmatically?
Thanks in advance,
Massimiliano Fanciulli
Re: File hiding in perspectives [message #331791 is a reply to message #331776] |
Mon, 22 September 2008 15:51 |
Massimiliano Fanciulli wrote:
> Hi All,
What View is showing the files? Note that I am not asking about the
Perspective, but rather the View (for example, Navigator, Project
Explorer, Package Explorer, etc).
For reference, the only View that shows the . files is the Navigator
view (I think). Package Explorer and Project Explorer do NOT show those
files by default.
Hope this helps,
Eric
Re: File hiding in perspectives [message #331805 is a reply to message #331791] |
Tue, 23 September 2008 09:22 |
Hi Eric,
yes i'm referring to the navigator view put in my perspective.
Massimiliano
>> Hi All,
>> and i have added some new perspectives. No problem with that except
>> for the fact that, when enabled, files with filename that start with a
>> dot are not hidden by default. Those files are not visible if, for
>> example, i activate the Java perspective. Can you tell me how to
>> enable/disable this behaviour programmatically?
> files by default.
> Hope this helps,
> Eric
Re: File hiding in perspectives [message #331813 is a reply to message #331805] |
Tue, 23 September 2008 13:12 |
> Hi Eric,
If you want the files hidden, you might want to consider using either
Project Explorer or Package Explorer views instead. Those views hide .*
files by default.
I think the Navigator view
(org.eclipse.ui.views.navigator.ResourceNavigator) can be configured
with a pattern filter to hide files, but you'd have to examine its API
to learn how to set them programatically.
Hope this helps,
Eric
>>> Hi All,
>>> in the documentation. I'm developing a plugin extension for eclipse
>>> 3.2 and i have added some new perspectives. No problem with that
>>> except for the fact that, when enabled, files with filename that
>>> start with a dot are not hidden by default. Those files are not
>>> visible if, for example, i activate the Java perspective. Can you
>>> tell me how to enable/disable this behaviour programmatically?
>> those files by default.
>> Hope this helps,
>> Eric
Current Time: Fri Sep 27 02:51:46 GMT 2024
Powered by FUDForum. Page generated in 0.03379 seconds
