[Databinding] using ValidationStatusProvider to link external validation framework [message #331772] |
Sun, 21 September 2008 19:03 |
Originally posted by: zx.code9.com
So here is my use case.
(1) I have some Java beans that act as model code.
(2) Databinding is used to bind the model some some UI widgets
(3) Databinding is also used to do validation
(4) There is also an external "global" validator that is used to do
validation to simplify the pain of writing validators for users. This
was done mainly to handle the complexities of validation when it is
across bindings... that is... you have elements that depend on each
other. I believe this could be done with MultiValidator in Databinding,
but we are trying hard to hide any Databinding code from developers.
I was looking at linking this "ICustomValidator" with databinding to
have one unified front of managing interactions. I believe this is
possible via ValidationStatusProvider but things are a bit tricky.
Any advice how to tackle this problem? Was anything done in EMF
Databinding to link EMF Validators with databinding?
This problem is slightly similar to what Riena is trying to with its
"Ridgets"
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.riena/o rg.eclipse.riena.sample.snippets/src/org/eclipse/riena/sampl e/snippets/SnippetTextRidget001.java?root=RT_Project&vie w=markup
We are trying to prevent users from writing complex databinding if they
don't have to.
Re: [Databinding] using ValidationStatusProvider to link external validation framework [message #331773 is a reply to message #331772] |
Sun, 21 September 2008 19:45 |
Ed Merks Messages: 33235 Registered: July 2009 |
--------------020107080908040302060807
Chris,
In EMF you can defined name constraints on EClassifiers (EClasses and
EDataTypes). Things like the facet constraints on simple types from XML
Schema are directly supported and you can add your own hand-implemented
named constraints:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.Validation.html
I'll bet it wouldn't be hard to hook up things like
Diagnostician.INSTANCE.validate to the data binding stuff. I'd be happy
to help explore that for the 2.5 release. Right now things like
EMFUpdateValueStrategy just help with the conversion from a String to a
value, which will yield messages about conversion problems, but it would
be interesting to ensure that the constraints are also enforce. E.g.,
10 might be a valid integer, but if the values are constrained to be > 2
and < 9 then it's still wrong...
> Databinding, but we are trying hard to hide any Databinding code from
> developers.
> "Ridgets"
> they don't have to.
<html>
<head>
</head>
Chris,<br>
<br>
XML Schema are directly supported and you can add your own
hand-implemented named constraints:<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.Validation.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.Validation.html</a><br>
</blockquote>
happy to help explore that for the 2.5 release. Right now things like
would be interesting to ensure that the constraints are also enforce.
E.g., 10 might be a valid integer, but if the values are constrained to
be > 2 and < 9 then it's still wrong...<br>
<br>
<br>
<br>
<blockquote cite="mid:gb65qm$av0$1@build.eclipse.org" type="cite">So
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
"Ridgets"
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.riena/o rg.eclipse.riena.sample.snippets/src/org/eclipse/riena/sampl e/snippets/SnippetTextRidget001.java?root=RT_Project&vie w=markup"> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.riena/o rg.eclipse.riena.sample.snippets/src/org/eclipse/riena/sampl e/snippets/SnippetTextRidget001.java?root=RT_Project&view=markup</a>
<br>
<br>
don't have to.
<br>
</blockquote>
</body>
</html>
--------------020107080908040302060807--
Ed Merks
FUDForum. Page generated in 0.03937 seconds
