Home » Eclipse Projects » Eclipse Platform » .project file changed listener
.project file changed listener [message #331760] Fri, 19 September 2008 16:23 Go to next message
Originally posted by: history222.ymail.com
For my plugin i need a listener for changes made to the project
description in the .project file.
Can somebody give me a hint?
-- Harald
Re: .project file changed listener [message #331766 is a reply to message #331760] Sat, 20 September 2008 02:32 Go to previous messageGo to next message
Originally posted by: subs._nospam_consertum.com
AFAIK, there isn't a listener specifically for that file. WWhat you need
is an IResourceChangeListener which will tell you about EVERY resource
change.
> Thanks
> -- Harald
Derek
Re: .project file changed listener [message #331786 is a reply to message #331766] Mon, 22 September 2008 10:50 Go to previous messageGo to next message
> change.
Is the definition of "EVERY resource" equal to "resources visible in the
Resource perspective"? If yes then this will probably not work as the
..project file is not visible in the resource perspective.
Robert
Re: .project file changed listener [message #331790 is a reply to message #331786] Mon, 22 September 2008 11:47 Go to previous message
Robert wrote:
>> need is an IResourceChangeListener which will tell you about EVERY
>> resource change.
1) Yes, IResourceChangeListener will get notified of any changes to
resources in the workspace. See this article for help writing your
listener so that it is efficient and effective:
http://www.eclipse.org/articles/Article-Resource-deltas/reso urce-deltas.html
2) I don't know what View you're looking at, but the Navigator view
(which is the "default" one that Resource perspective opens with) does
indeed show .project files.
Hope this helps,
Eric
Previous Topic:Debugger Plug-in: Extending Variables View - Advice Please
Next Topic:Posting eclipse zips on maven repository
Current Time: Mon Dec 01 18:15:49 EST 2025
Powered by FUDForum. Page generated in 0.04052 seconds
