Home » Eclipse Projects » Eclipse Platform » Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows Vista
Re: Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows [message #331752 is a reply to message #331719] |
Fri, 19 September 2008 15:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Steffen Zschaler![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=steffen.zschaler%40kcl.ac.uk) Messages: 266 Registered: July 2009 |
I have not received any responses from this newsgroup (or any of the
other places I posted). But, based on a hint from a colleague and some
experimenting, I found out that it works for me if I put Eclipse in a
writeable place. In my case, I used C:\eclipse instead of (the more
logical [sic!]) C:\Program Files\eclipse. Now all plugins end up
directly in the eclipse folder and all is well.
I would consider this behaviour a bug in P2, or at least something that
definitely needs documentation. Where would I submit such a bug report?
Steffen
Alexander Broekhuis schrieb:
> Did you find a solution for this problem? I have exaclty the same
> problem, but am on linux.
> Eclipse is installed read-only and is used by multiple users. Installing
> plugins using p2 installs them somewhere in my home/.eclipse. Which is
> correct. But as you, the bundles.info are different.
> Is it possible and safe to just change the location of the bundles.info
> in a startup script?
> TiA!
> Alexander
> Steffen Zschaler wrote:
>> Hi again,
>> I found some more info and did some more looking around. It seems that
>> P2 will store the list of installed bundles in a bundles.info file
>> somewhere in the configuration space of the eclipse directory. In my
>> situation, I now have two such bundles.info files, one under
>> C:Programmeeclipse... and one under C:Users<Current User>.eclipse.
>> These two files are substantially different. Could it be that
>> different parts of Eclipse actually use different of these files? How
>> could I prevent this?
>> Thanks again,
>> Steffen
Dr. rer. nat. Steffen Zschaler
Research Associate
Technische Universität Dresden
Department of Computer Science
Phone +49 351 463 38555
Fax +49 351 463 38459
Email Steffen.Zschaler@tu-dresden.de
WWW http://www.steffen-zschaler.de/
Interested in Software Languages? Have you heard of the all-new
1st International Conference on Software Language Engineering?
Be sure to visit the web site: http://planet-sl.org/sle2008/
Consider coming to QoSA 2008, the 4th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider coming to MNPSC 2008, the IEEE International Workshop on
Methodologies for Non-functional Properties in Services Computing
http://www.cs.umb.edu/~jxs/mnpsc/
Re: Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows [message #331789 is a reply to message #331752] |
Mon, 22 September 2008 15:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Bug reports go to http://bugs.eclipse.org/bugs
> Steffen
>> Installing plugins using p2 installs them somewhere in my
>> home/.eclipse. Which is correct. But as you, the bundles.info are
>> different.
>> bundles.info in a startup script?
>> TiA!
>> Alexander
>>> Hi again,
>>> that P2 will store the list of installed bundles in a bundles.info
>>> file somewhere in the configuration space of the eclipse directory.
>>> In my situation, I now have two such bundles.info files, one under
>>> Thanks again,
>>> Steffen
Re: Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows [message #331801 is a reply to message #331752] |
Tue, 23 September 2008 07:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Alexander ![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=a.broekhuis%40gmail.com) Messages: 23 Registered: July 2009 |
Junior Member |
When running on multi-users systems, that isn't a solution for user
plugins :).
As for the bundles.info being different, the one in the user home dir has
the extra bundles that are installed by the user, and as far as I can tell
the correct bundles.info is being used. So that seems to be ok.
Did you post a bug? If so, what is the nr/link? I found some issues about
not having a dropin location per user etc, but not one about this problem
where plugins seem to be present (the menu items are all there), but can't
be selected as plugin dependency.
Alexander
> writeable place. In my case, I used C:eclipse instead of (the more
> logical [sic!]) C:Program Fileseclipse. Now all plugins end up
> Steffen
>> TiA!
>> Alexander
>>> Hi again,
>>> Thanks again,
>>> Steffen
Re: Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows [message #331908 is a reply to message #331801] |
Sun, 28 September 2008 14:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I've been off-line for some time and haven't had time to submit the bug.
Was trying to do so earlier today, but am still waiting for my
confirmation mail for the bugzilla account...
Steffen
> plugins :).
> has the extra bundles that are installed by the user, and as far as I
> can tell the correct bundles.info is being used. So that seems to be ok.
> about not having a dropin location per user etc, but not one about this
> problem where plugins seem to be present (the menu items are all there),
> but can't be selected as plugin dependency.
> Alexander
>> that definitely needs documentation. Where would I submit such a bug
>> report?
>> Steffen
>>> Hi,
>>> different.
>>> TiA!
>>> Alexander
>>>> Hi again,
>>>> How could I prevent this?
>>>> Thanks again,
>>>> Steffen
Research Associate
Re: Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows [message #331912 is a reply to message #331908] |
Mon, 29 September 2008 07:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Just submitted the bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=248893
Steffen
Steffen Zschaler schrieb:
> Steffen
>> plugins :).
>> this problem where plugins seem to be present (the menu items are all
>> there), but can't be selected as plugin dependency.
>> Alexander
>>> Hi,
>>> some experimenting, I found out that it works for me if I put Eclipse
>>> in a writeable place. In my case, I used C:eclipse instead of (the
>>> more logical [sic!]) C:Program Fileseclipse. Now all plugins end up
>>> report?
>>> Steffen
>>>> Hi,
>>>> different.
>>>> TiA!
>>>> Alexander
>>>>> Hi again,
>>>>> User>.eclipse. These two files are substantially different. Could
>>>>> it be that different parts of Eclipse actually use different of
>>>>> these files? How could I prevent this?
>>>>> Thanks again,
>>>>> Steffen
Research Associate
Re: Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows [message #331918 is a reply to message #331912] |
Mon, 29 September 2008 13:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
Thx,
I subscribed to it..
> Steffen
>> Steffen
>>> Hi,
>>> plugins :).
>>> Alexander
>>>> Hi,
>>>> report?
>>>> Steffen
>>>>> Hi,
>>>>> different.
>>>>> TiA!
>>>>> Alexander
>>>>>> Hi again,
>>>>>> Thanks again,
>>>>>> Steffen
Current Time: Thu Jul 18 01:04:42 GMT 2024
Powered by FUDForum. Page generated in 0.03691 seconds
