Q regarding order of contributed menus to popup menus [message #331698] |
Wed, 17 September 2008 06:33 |
Originally posted by: no.ddress.now
So I am able to add a menu to the JDT Editor and Outline popup menus
and, functionally, they work.
The problem is that the menu location in the popup menu is not
consistant for path="group.show". For the JDT Editor, my menu is being
added immeditely *above* "Show In" and for the JDT Outline, it is
immediately *below* "Show In".
If I specify path="additions" for both, then my menu shows up
immediately above "Run" in the JDT Editor popup menu and immediately
below "Restore from local history" in the Outline popup menu.
Is there a way to enforce/ensure consistent placement of my menu? Or,
is there something incorrect about my configuration?
<extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
id="net.certiv.visualization.cgv.callgraphActions"
targetID="#CompilationUnitEditorContext">
<menu
id="callGraphEditorMenu"
label="Call Graph"
path="group.show">
<separator name="group1" />
</menu>
<action
</action>
</viewerContribution>
<objectContribution
adaptable="false"
id="net.certiv.visualization.cgv.callgraphActions1"
objectClass="org.eclipse.jdt.core.IMember">
<menu
id="callGraphViewMenu"
label="Call Graph"
path="group.show">
<separator name="group2" />
</menu>
<action
</action>
</objectContribution>
</extension>
Gerald
Re: Q regarding order of contributed menus to popup menus [message #331728 is a reply to message #331724] |
Thu, 18 September 2008 14:30 |
In article <gatnis$fj6$1@build.eclipse.org>, pwebster@ca.ibm.com
says...
> With object and viewer contributions, the order of processing is
> non-deterministic. You can only work around this by using groups to
> specify order, but 2 contributions at the same "group" can be added in
> any order (that includes your menu vs the Show In menu).
> There are some potential hacks available in 3.3 and 3.4, but I'm not
> sure if they are a good idea.
> PW
Thanks, Paul.
Is there any documentation at all on the 3.4 hack? Not sure which is
worse, the hack or having UI elements show in inconsistant locations.
Best,
Gerald
FUDForum. Page generated in 0.04046 seconds
