Home » Eclipse Projects » Eclipse Platform » Export-Package version when creating Plug-in from existing JAR archives
Export-Package version when creating Plug-in from existing JAR archives [message #331688] Tue, 16 September 2008 10:41 Go to next message
When using Eclipse to develop OSGi bundles you quite often need to
"osgify" external libraries.
To do this you can use "File -> New -> Project -> Plug-in Development ->
Plug-in from existing JAR archives"
When plug-in is created, the "Export-Package" entries in the generated
MANIFEST do not hold any version attribute.
According to OSGi R4 specs it means exported packages do have version
"0.0.0" instead of having the same version as the Bundle-Version metatag.
Missing versioning from Export-Package and Import-Package metatags is a
common issue in OSGi development and specifying them is considered as a
"best practice".
Don't you think the "Plug-in from existing JAR archives" functionnality
should by default add version attribute to ""Export-Package" entries ?
The version value would be the same as the "Bundle-Version"
Frederic
Re: Export-Package version when creating Plug-in from existing JAR archives [message #331691 is a reply to message #331688] Tue, 16 September 2008 11:45 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Frederic Conrotte wrote:
> Hello,
> "best practice".
That sounds like a fair suggestions.
Do you mind filing bug against PDE?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=PDE
By the way, in 3.5M2, PDE added support for flagging missing version
numbers on exported packages, imported packages and require bundle
versions. That should help people if they want to make sure version
constraint information is included on their projects.
~ Chris
Re: Export-Package version when creating Plug-in from existing JAR archives [message #331695 is a reply to message #331691] Tue, 16 September 2008 16:06 Go to previous message
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247553
Though I tried to dig, I was unsure if such request was already in bugzilla.
Cool stuff. Thanks for the tip.
Fred
Previous Topic:Replacing Editor Icons at workbench startup
Next Topic:Editor and Outline view integration
Current Time: Tue Oct 21 12:05:11 EDT 2025
Powered by FUDForum. Page generated in 0.04264 seconds
