Home » Eclipse Projects » Eclipse Platform » Restart eclipse from command line
Restart eclipse from command line [message #331478] Tue, 09 September 2008 09:28 Go to next message
I have a perl script that install various plug-ins from the command line
using the equinox jar. What I am missing is a restart of eclipse ( if
running) to make the new plugins show up. Is it possible to restart
eclipse from the command line?
cheers,
//mike
Re: Restart eclipse from command line [message #331485 is a reply to message #331478] Tue, 09 September 2008 16:14 Go to previous messageGo to next message
The only way I know to do something like this was if the running eclipse
was running with the console on some port (-console 9000), you can then
telnet to that port and issue commands to the osgi framework. exit,
shutdown, and close will all stop the running eclipse, but I couldn't
get it to return the proper exit code 23 to cause a restart, so the perl
script would need to do the restart itself.
An alternative would be to install a plug-ins that opened a socket and
listened for commands to restart eclipse from within.
-Andrew
Mikael Petterson wrote:
> cheers,
> //mike
Re: Restart eclipse from command line [message #331493 is a reply to message #331478] Wed, 10 September 2008 07:08 Go to previous message
Originally posted by: bullet.magnet.example.com
mikaelpetterson@hotmail.com (Mikael Petterson) wrote in
news:ac8036ed549bfac9f41da4e66ee2d897$1@www.eclipse.org:
> cheers,
> //mike
You could kill and relaunch the eclipse process
Life is complex, with real and imaginary parts.
Previous Topic:"convert line-delimiters" in Eclipse UI?
Next Topic:Editor status info placement
Current Time: Tue Sep 16 05:38:07 EDT 2025
Powered by FUDForum. Page generated in 0.07686 seconds
