Home » Eclipse Projects » Eclipse Platform » Get workbench's toolbar
Get workbench's toolbar [message #331461] Mon, 08 September 2008 15:24 Go to next message
Originally posted by: spam.korgen.de
Hi everybody,
I'm desperately trying to get the toolbar of the Eclipse Window. I
defined an extension of type action to org.eclipse.ui.actionSets and now
I'm trying to access the corresponding toolbar entry to disable it.
How can this be done?
Thanks a lot
Joerg
Re: Get workbench's toolbar [message #331475 is a reply to message #331461] Tue, 09 September 2008 07:37 Go to previous message
Korgen wrote:
> Hi everybody,
You can't really get the workbench toolbar that way (you could use SWT
hackery, but the workbench will overwrite your changes the first chance
it gets).
If you are using actionSets, the correct way to enabled/disable your
IAction is in org.eclipse.ui.IActionDelegate.selectionChanged(IAction,
ISelection)
action.setEnabled(false) will disable it.
Later,
PW
Paul Webster
Previous Topic:How to participate in cut / copy / paste?
Next Topic:Ganymede Update Problems
Current Time: Sat Nov 01 20:50:03 EDT 2025
Powered by FUDForum. Page generated in 0.58418 seconds
