Home » Eclipse Projects » Eclipse Platform » CompletionProposal final?
CompletionProposal final? [message #331437] Fri, 05 September 2008 19:57 Go to next message
Hi All,
I'm implementing this eclipse plugin that will be IDE for a programming
language. I would like to use the Content Assist (or Autocomplete)
feature. I'm actually using it but i would like my documentation to appear
on the right as in JDT. I'm actually doing this too, but I would like the
string i put there to be formated better. I see eclipse has
ICompletionProposalExtensions and the 6-th one looks like what i need. So
i tried to extend the CompletionProposal class and implement
ICompletionProposalExtension6 but CompletionProposal is final ;(.
What should i do now?
Nikola
Re: CompletionProposal final? [message #331453 is a reply to message #331437] Mon, 08 September 2008 08:48 Go to previous message
Nikola Borisov wrote:
> Hi All,
> programming language. I would like to use the Content Assist (or
> Autocomplete) feature. I'm actually using it but i would like my
> documentation to appear on the right as in JDT. I'm actually doing
> this too, but I would like the string i put there to be formated
> better. I see eclipse has ICompletionProposalExtensions and the 6-th
> one looks like what i need. So i tried to extend the
> CompletionProposal class and implement ICompletionProposalExtension6
Use it as template to implement your own class.
Dani
> Thanks
> Nikola
Previous Topic:Solution of ContentAssist Problem
Next Topic:Plug-in JUnit Tests and native DLL - classpath issues
Current Time: Tue Apr 29 02:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.06284 seconds
