returning an exit code [message #331387] |
Thu, 04 September 2008 08:59 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: subs._nospam_consertum.com
Does anybody have any suggestions on how I might pass an 'exit code' to
a script that invokes eclipse?
I have written an Eclipse plugin that allows certain operations to be
performed in a 'batch' mode and then exit. This is working. I am trying
to find a way to pass the success/fail status to a shell script that
started Eclipse.
I have tried
System.setProperty("eclipse.exitcode", 999);
workbench.close() ;
but the exit code from the Eclipse executable is always zero. It seems
that Workbench#close() always sets the 'return code' to zero.
I am writing status information to a file, so I could add something to
that, but the script would then need to read the file (which I am trying
to avoid).
I had thought about using environment variables, but there is no way to
set one using Java.
Any other thoughts?
Derek
FUDForum. Page generated in 0.03118 seconds
