Re: Creating a perspective on Runtime [message #331380 is a reply to message #331355] |
Thu, 04 September 2008 07:25 |
On Wed, 3 Sep 2008 13:20:32 +0000 (UTC), jko@swisslab.de (Jan Kohnert)
wrote:
>Hello,
>I'm writing an RCP applikation that runs several instances of processes
>that hold one to many instances of tasks performing file transformations.
>(like a cron processor).
>I want for each processor instance one perspective that hold one view for
>each task run by the processor.
>So far I have all views of all tasks run within one perspective.
>Since I dont know how many processors will finally run I need to create
>the perspectives flexible at application startup.
>How can I crate a perspective at runtime? Is this possible?
>Thanks,
>Jan Kohnert
I've only found an internal class to do this. You can look into
SavePerspectiveAction to see how a user modified perspective is saved.
Unfortunitely there are classes from org.eclipse.ui.internal invoked.
You may use these classes but the API is not guranteed.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Achim Lörke
FUDForum. Page generated in 0.03159 seconds
