[Data Binding] Re: Widget [org.eclipse.swt.custom.StyledText] is not supported. [message #331339] |
Tue, 02 September 2008 11:15  |
Francis ANDRE wrote:
> Hello
> got this exception
> Exception in thread "main" java.lang.IllegalArgumentException: Widget
> at
> org.eclipse.jface.databinding.swt.SWTObservables.observeText (SWTObservables.java:217)
> at databinding.view.View.createShell(View.java:76)
> at databinding.driver.IBM3270$1.run(IBM3270.java:23)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at databinding.driver.IBM3270.main(IBM3270.java:20)
> Why StyledText is not supported while Text is?? (May be it is a stupid
> question but I am a little perplex since a StyledText is somewhat a Text
> too)
I'm copying this to the eclipse.platform newsgroup where Data Binding
questions are usually directed.
Have you looked for or entered a feature request in Bugzilla for that?
It looks like TextObservableValue (which is what
SWTObservables.observeText() delegates to) only relies on
addVerifyListener(), getText(), and setText(), so on the surface it
seems that StyledText support should be doable.
You could always write your own StyledTextObservableValue, of course and
contribute that to the project.
If you enter a feature request into Bugzilla, please post the link here.
Eric
Re: [Data Binding] Re: Widget [org.eclipse.swt.custom.StyledText] is not supported. [message #331467 is a reply to message #331339] |
Mon, 08 September 2008 19:33  |
This is on the table for 3.5, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=131435
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g9jl7l$qnn$1@build.eclipse.org...
>> Hello
>> got this exception
>> at
>> at
>> too)
> Have you looked for or entered a feature request in Bugzilla for that? It
> looks like TextObservableValue (which is what SWTObservables.observeText()
> delegates to) only relies on addVerifyListener(), getText(), and
> setText(), so on the surface it seems that StyledText support should be
> doable.
> Eric
FUDForum. Page generated in 0.08698 seconds
