Re: Plugin.xml not translated! [message #331332 is a reply to message #331331] |
Tue, 02 September 2008 06:14 |
Originally posted by: subs._nospam_consertum.com
yau wrote:
> Hi!
> I was defined a extension for the org.eclipse.ui.views, in the plugin.xml, I
> specified an stub value "%dwservice.mailNavigator" for the "name" attribute
> of the view, as following:
> <view
> class="org.eclipse.ui.navigator.CommonNavigator"
> icon="icons/mail-navigator-icon.gif"
> id="cn.com.dwservice.mail.MailNavigator"
> name="%dwservice.mailNavigator"
> restorable="true">
> </view>
> And in the plugin.properties I have made an translate entry for it.
> At design time, it is OK, the IDE show the correct translated name in the
> extensions editor, but at runtime, the view's tab text shows the raw value
> "%dwservice.mailNavigator".
> What's wrong?
> -yau
Have you included plugin.properites in the build?
Derek
Re: Plugin.xml not translated! [message #331338 is a reply to message #331331] |
Tue, 02 September 2008 14:40 |
Originally posted by: zx.code9.com
yau wrote:
> Hi!
> <view
> restorable="true">
> </view>
> What's wrong?
Are you missing Bundle-Localization: plugin
in your MANIFEST.MF?
~ Chris
Re: Plugin.xml not translated! [message #331348 is a reply to message #331332] |
Wed, 03 September 2008 00:46 |
yau Messages: 14 Registered: July 2009 |
Junior Member |
"Derek" <subs@_nospam_consertum.com>
??????:g9ilkh$7rk$1@build.eclipse.org...
> yau wrote:
>> Hi!
>> plugin.xml, I specified an stub value "%dwservice.mailNavigator" for the
>> "name" attribute of the view, as following:
>> <view
>> restorable="true">
>> </view>
>> value "%dwservice.mailNavigator".
>> What's wrong?
>> -yau
> Derek
No, I have not, but the problem as of old after I includes the
plugin.properties into build, the problem actually is I am missing following
line:
in my plugin's MANIFEST.MF.
Yau K.J
Re: Plugin.xml not translated! [message #331349 is a reply to message #331338] |
Wed, 03 September 2008 01:01 |
Junior Member |
"Chris Aniszczyk" <zx@code9.com> ??????:g9jj9d$gmk$1@build.eclipse.org...
> yau wrote:
>> Hi!
>> <view
>> restorable="true">
>> </view>
>> What's wrong?
> Cheers,
> ~ Chris
Yes, you are right. Thank you very much!
The other thing I'd like to say is the 2 article on
www.eclipse.org/resources/ :
<<How to Internationalize your Eclipse Plug-In>>
<<How to Test Your Internationalized Eclipse Plug-In>>
was not point out this requirement for translation of the plugin.xml.
I think it may be helpful for the newer if the above articles point out this
information and if my problem is a common case.
Yau K.J.
FUDForum. Page generated in 0.10185 seconds
