Re: "Ignored reentrant call while viewer is busy"? [message #331337 is a reply to message #331289] |
Tue, 02 September 2008 13:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
My guess is because you are already in a replace (which probably marks
the viewer as busy) and you can't do another replace until the previous
is finished.
> !ENTRY org.eclipse.jface 2 0 2008-08-28 21:05:17.515
> !MESSAGE Ignored reentrant call while viewer is busy. This is only
> logged once per viewer instance, but similar calls will still be ignored.
> !STACK 0
> java.lang.RuntimeException
> at org.eclipse.jface.viewers.ColumnViewer.isBusy(ColumnViewer.j ava:79)
> at
>>>>>> org.eclipse.jface.viewers.AbstractTableViewer.replace(Abstra ctTableViewer.java:1035)
> at
> com.ibm.udat.statistics.view.impl.StatisticsViewerImpl$TypeC ontents.updateElement(StatisticsViewerImpl.java:621)
> at
> org.eclipse.jface.viewers.StructuredViewer.refreshItem(Struc turedViewer.java:1479)
> at
>>>>>> org.eclipse.jface.viewers.AbstractTableViewer.replace(Abstra ctTableViewer.java:1038)
> at
Rich Kulp
FUDForum. Page generated in 0.03012 seconds
