Home » Eclipse Projects » Eclipse Platform » resource still out of sync after refreshLocal
resource still out of sync after refreshLocal [message #331261] Thu, 28 August 2008 12:16 Go to next message
I am experiencing problems with the refreshLocal method. I call it right
after a file is modified using some java.io classes, but when I try to
open or delete this file afterwards, I get the message that the resource
is out of sync. However, if I refresh manually (F5), it works. Any idea
what might be wrong?
Here is the code (slightly modified), where modifyFilesInContainer
modifies the files, after that refreshLocal is called. I have no idea what
the problem could possibly be.
IContainer container = getWorkspace().getRoot().getFolder("test");
modifyFilesInContainer(container);
try {
container.refreshLocal(IResource.DEPTH_INFINITE, null);
} catch (CoreException e) {
Best,
Anton
Re: resource still out of sync after refreshLocal [message #331286 is a reply to message #331261] Thu, 28 August 2008 16:27 Go to previous messageGo to next message
> try {
I know this is just sample code but I don't know how literal you're
being... any chance that refreshLocal is, in fact, throwing an exception
that is being ignored?
Re: resource still out of sync after refreshLocal [message #331288 is a reply to message #331286] Thu, 28 August 2008 19:33 Go to previous messageGo to next message
No, the catch block adds the exception to the Error-Log View, so I am
pretty sure that no exception is thrown.
Re: resource still out of sync after refreshLocal [message #331292 is a reply to message #331261] Fri, 29 August 2008 02:49 Go to previous message
Anton Pussep wrote:
> right after a file is modified using some java.io classes, but when I
> try to open or delete this file afterwards, I get the message that the
> resource is out of sync. However, if I refresh manually (F5), it
> works. Any idea what might be wrong?
Are you sure the changes via java.io are flushed and the file no longer
locked when you call refreshLocal? Also, are you doing the refresh in
the UI thread or some other thread that might refresh after the UI
accesses the file?
Dani
> what the problem could possibly be.
> try {
> Best,
> Anton
Previous Topic:Enable disable action set
Next Topic:ILazyContentProvider updateElement(index) gets called for non-existent elements
Current Time: Sat Oct 25 09:43:12 EDT 2025
Powered by FUDForum. Page generated in 0.04767 seconds
