Re: Table Text Cell Editor with Completion Proposals [message #331251 is a reply to message #331212] |
Thu, 28 August 2008 15:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mario.winterer.gmx.net
In our project, I've simply subclassed TextCellEditor.
For content proposal I'm using the field assist API of JFace
(org.eclipse.jface.fieldassist). In our code, content assist is enabled
when the cell editor is activated for the first time:
if (contentProposalAdapter == null) {
// enable content assist on the cell editor's text widget
contentProposalAdapter = new ContentProposalAdapter(text,
new TextContentAdapter(), proposalProvider,
activationKeyStroke, null);
} else {
contentProposalAdapter.setEnabled(true);
super.activate();
Make sure to also override method
TextCellEditor#dependsOnExternalFocusListener() to return false always.
Otherwise you'll face some serious problems concerning focus.
Mario
kentusha schrieb:
> I am looking for a table text cell editor that supports Auto Completion
> proposals.
> I found TableTextCellEditor in org.eclipse.jdt.internal.ui.dialogs, but
> it uses the deprecated SubjectControlContentAssistant.
> I am quite happy to change it to use the replacement classes but
> SubjectControlContentAssistant only says "As of 3.2, replaced by
> Platform UI's field assist support", which doesn't really help me enough
> to find the replacement functionality.
> So does anyone know which class or classes now replace
> SubjectControlContentAssistant or does anyone now of a table text cell
> editor that supports content assistance.
> thanks
Re: Table Text Cell Editor with Completion Proposals [message #331295 is a reply to message #331270] |
Fri, 29 August 2008 08:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hm. I could prepare one by removing domain specific stuff.
>> always. Otherwise you'll face some serious problems concerning focus.
> Right this was introduced for this special feature. Mario do you have a
> simple Snippet we can upload to our collection?
> Tom
Re: Table Text Cell Editor with Completion Proposals [message #331298 is a reply to message #331296] |
Fri, 29 August 2008 10:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------060406090807050107080303
It's already done! I've used another snippet and changed it for my
purpose. Its added as attachment.
> Or you could use one of the existing ones and simply add the
> ContentProposal.
> Looks like: http://wiki.eclipse.org/JFaceSnippets#Snippet025TabEditing
> should be easy to adjust so that it adds ContentProposal.
> Tom
>>> a simple Snippet we can upload to our collection?
>>> Tom
name="SnippetTextCellEditorWithContentProposal.java"
Content-Disposition: inline;
filename="SnippetTextCellEditorWithContentProposal.java"
cGFja2FnZSBvcmcuZWNsaXBzZS5qZmFjZS5zbmlwcGV0cy52aWV3ZXJzOw0K DQppbXBvcnQg
b3JnLmVjbGlwc2UuamZhY2UuYmluZGluZ3Mua2V5cy5JS2V5TG9va3VwOw0K aW1wb3J0IG9y
Zy5lY2xpcHNlLmpmYWNlLmJpbmRpbmdzLmtleXMuS2V5TG9va3VwRmFjdG9y eTsNCmltcG9y
dCBvcmcuZWNsaXBzZS5qZmFjZS5iaW5kaW5ncy5rZXlzLktleVN0cm9rZTsN CmltcG9ydCBv
cmcuZWNsaXBzZS5qZmFjZS5maWVsZGFzc2lzdC5Db250ZW50UHJvcG9zYWxB ZGFwdGVyOw0K
aW1wb3J0IG9yZy5lY2xpcHNlLmpmYWNlLmZpZWxkYXNzaXN0LklDb250ZW50 UHJvcG9zYWxM
aXN0ZW5lcjI7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZhY2UuZmllbGRhc3Np c3QuSUNvbnRl
bnRQcm9wb3NhbFByb3ZpZGVyOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmpmYWNl LmZpZWxkYXNz
aXN0LlNpbXBsZUNvbnRlbnRQcm9wb3NhbFByb3ZpZGVyOw0KaW1wb3J0IG9y Zy5lY2xpcHNl
LmpmYWNlLmZpZWxkYXNzaXN0LlRleHRDb250ZW50QWRhcHRlcjsNCmltcG9y dCBvcmcuZWNs
aXBzZS5qZmFjZS52aWV3ZXJzLkFycmF5Q29udGVudFByb3ZpZGVyOw0KaW1w b3J0IG9yZy5l
Y2xpcHNlLmpmYWNlLnZpZXdlcnMuQ2VsbEVkaXRvcjsNCmltcG9ydCBvcmcu ZWNsaXBzZS5q
ZmFjZS52aWV3ZXJzLkNvbHVtbkxhYmVsUHJvdmlkZXI7DQppbXBvcnQgb3Jn LmVjbGlwc2Uu
amZhY2Uudmlld2Vycy5Db2x1bW5WaWV3ZXJFZGl0b3I7DQppbXBvcnQgb3Jn LmVjbGlwc2Uu
amZhY2Uudmlld2Vycy5Db2x1bW5WaWV3ZXJFZGl0b3JBY3RpdmF0aW9uRXZl bnQ7DQppbXBv
cnQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5Db2x1bW5WaWV3ZXJFZGl0 b3JBY3RpdmF0
aW9uU3RyYXRlZ3k7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vy cy5FZGl0aW5n
U3VwcG9ydDsNCmltcG9ydCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLkZv Y3VzQ2VsbEhp
Z2hsaWdodGVyOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmpmYWNlLnZpZXdlcnMu Rm9jdXNDZWxs
T3duZXJEcmF3SGlnaGxpZ2h0ZXI7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZh Y2Uudmlld2Vy
cy5UYWJsZVZpZXdlcjsNCmltcG9ydCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3 ZXJzLlRhYmxl
Vmlld2VyQ29sdW1uOw0KaW1wb3J0IG9yZy5lY2xpcHNlLmpmYWNlLnZpZXdl cnMuVGFibGVW
aWV3ZXJFZGl0b3I7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vy cy5UYWJsZVZp
ZXdlckZvY3VzQ2VsbE1hbmFnZXI7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZh Y2Uudmlld2Vy
cy5UZXh0Q2VsbEVkaXRvcjsNCmltcG9ydCBvcmcuZWNsaXBzZS5zd3QuU1dU Ow0KaW1wb3J0
IG9yZy5lY2xpcHNlLnN3dC5sYXlvdXQuRmlsbExheW91dDsNCmltcG9ydCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5Db21wb3NpdGU7DQppbXBvcnQgb3JnLmVjbGlwc2Uu c3d0LndpZGdl
dHMuRGlzcGxheTsNCmltcG9ydCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5T aGVsbDsNCmlt
cG9ydCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5UYWJsZTsNCg0KLyoqDQog KiBTaG93cyBo
b3cgdG8gZW5hYmxlIGNvbnRlbnQgYXNzaXN0IGluIGEgdGV4dCBjZWxsIGVk aXRvci4NCiAq
IA0KICogQGF1dGhvciBNYXJpbyBXaW50ZXJlcg0KICovDQpwdWJsaWMgY2xh c3MgU25pcHBl
dFRleHRDZWxsRWRpdG9yV2l0aENvbnRlbnRQcm9wb3NhbCB7DQoJcHJpdmF0 ZSBzdGF0aWMg
Y2xhc3MgQ29sb3Igew0KCQlwdWJsaWMgU3RyaW5nIG5hbWU7DQoNCgkJcHVi bGljIENvbG9y
KFN0cmluZyBuYW1lKSB7DQoJCQl0aGlzLm5hbWUgPSBuYW1lOw0KCQl9DQoN CgkJQE92ZXJy
aWRlDQoJCXB1YmxpYyBTdHJpbmcgdG9TdHJpbmcoKSB7DQoJCQlyZXR1cm4g bmFtZTsNCgkJ
fQ0KCX0NCg0KCXB1YmxpYyBzdGF0aWMgY2xhc3MgVGV4dENlbGxFZGl0b3JX aXRoQ29udGVu
dFByb3Bvc2FsIGV4dGVuZHMgVGV4dENlbGxFZGl0b3Igew0KDQoJCXByaXZh dGUgQ29udGVu
dFByb3Bvc2FsQWRhcHRlciBjb250ZW50UHJvcG9zYWxBZGFwdGVyOw0KCQlw cml2YXRlIGJv
b2xlYW4gcG9wdXBPcGVuID0gZmFsc2U7IC8vIHRydWUsIGlmZiBwb3B1cCBp cyBjdXJyZW50
bHkgb3Blbg0KDQoJCXB1YmxpYyBUZXh0Q2VsbEVkaXRvcldpdGhDb250ZW50 UHJvcG9zYWwo
Q29tcG9zaXRlIHBhcmVudCwgSUNvbnRlbnRQcm9wb3NhbFByb3ZpZGVyIGNv bnRlbnRQcm9w
b3NhbFByb3ZpZGVyLA0KCQkJCUtleVN0cm9rZSBrZXlTdHJva2UsIGNoYXJb XSBhdXRvQWN0
aXZhdGlvbkNoYXJhY3RlcnMpIHsNCgkJCXN1cGVyKHBhcmVudCk7DQoNCgkJ CWVuYWJsZUNv
bnRlbnRQcm9wb3NhbChjb250ZW50UHJvcG9zYWxQcm92aWRlciwga2V5U3Ry b2tlLCBhdXRv
QWN0aXZhdGlvbkNoYXJhY3RlcnMpOw0KCQl9DQoNCgkJcHJpdmF0ZSB2b2lk IGVuYWJsZUNv
bnRlbnRQcm9wb3NhbChJQ29udGVudFByb3Bvc2FsUHJvdmlkZXIgY29udGVu dFByb3Bvc2Fs
UHJvdmlkZXIsIEtleVN0cm9rZSBrZXlTdHJva2UsDQoJCQkJY2hhcltdIGF1 dG9BY3RpdmF0
aW9uQ2hhcmFjdGVycykgew0KCQkJY29udGVudFByb3Bvc2FsQWRhcHRlciA9 IG5ldyBDb250
ZW50UHJvcG9zYWxBZGFwdGVyKHRleHQsIG5ldyBUZXh0Q29udGVudEFkYXB0 ZXIoKSwNCgkJ
CQkJY29udGVudFByb3Bvc2FsUHJvdmlkZXIsIGtleVN0cm9rZSwgYXV0b0Fj dGl2YXRpb25D
aGFyYWN0ZXJzKTsNCg0KCQkJLy8gTGlzdGVuIGZvciBwb3B1cCBvcGVuL2Ns b3NlIGV2ZW50
cyB0byBiZSBhYmxlIHRvIGhhbmRsZSBmb2N1cyBldmVudHMgY29ycmVjdGx5 DQoJCQljb250
ZW50UHJvcG9zYWxBZGFwdGVyLmFkZENvbnRlbnRQcm9wb3NhbExpc3RlbmVy KG5ldyBJQ29u
dGVudFByb3Bvc2FsTGlzdGVuZXIyKCkgew0KDQoJCQkJcHVibGljIHZvaWQg cHJvcG9zYWxQ
b3B1cENsb3NlZChDb250ZW50UHJvcG9zYWxBZGFwdGVyIGFkYXB0ZXIpIHsN CgkJCQkJcG9w
dXBPcGVuID0gZmFsc2U7DQoJCQkJfQ0KDQoJCQkJcHVibGljIHZvaWQgcHJv cG9zYWxQb3B1
cE9wZW5lZChDb250ZW50UHJvcG9zYWxBZGFwdGVyIGFkYXB0ZXIpIHsNCgkJ CQkJcG9wdXBP
cGVuID0gdHJ1ZTsNCgkJCQl9DQoJCQl9KTsNCgkJfQ0KDQoJCS8qKg0KCQkg KiBSZXR1cm4g
dGhlIHtAbGluayBDb250ZW50UHJvcG9zYWxBZGFwdGVyfSBvZiB0aGlzIGNl bGwgZWRpdG9y
Lg0KCQkgKiANCgkJICogQHJldHVybiB0aGUge0BsaW5rIENvbnRlbnRQcm9w b3NhbEFkYXB0
ZXJ9DQoJCSAqLw0KCQlwdWJsaWMgQ29udGVudFByb3Bvc2FsQWRhcHRlciBn ZXRDb250ZW50
UHJvcG9zYWxBZGFwdGVyKCkgew0KCQkJcmV0dXJuIGNvbnRlbnRQcm9wb3Nh bEFkYXB0ZXI7
DQoJCX0NCg0KCQlAT3ZlcnJpZGUNCgkJcHJvdGVjdGVkIHZvaWQgZm9jdXNM b3N0KCkgew0K
CQkJaWYgKCFwb3B1cE9wZW4pIHsNCgkJCQkvLyBGb2N1cyBsb3N0IGRlYWN0 aXZhdGVzIHRo
ZSBjZWxsIGVkaXRvci4NCgkJCQkvLyBUaGlzIG11c3Qgbm90IGhhcHBlbiBp ZiBmb2N1cyBs
b3N0IHdhcyBjYXVzZWQgYnkgYWN0aXZhdGluZw0KCQkJCS8vIHRoZSBjb21w bGV0aW9uIHBy
b3Bvc2FsIHBvcHVwLg0KCQkJCXN1cGVyLmZvY3VzTG9zdCgpOw0KCQkJfQ0K CQl9DQoNCgkJ
QE92ZXJyaWRlDQoJCXByb3RlY3RlZCBib29sZWFuIGRlcGVuZHNPbkV4dGVy bmFsRm9jdXNM
aXN0ZW5lcigpIHsNCgkJCS8vIEFsd2F5cyByZXR1cm4gZmFsc2U7DQoJCQkv LyBPdGhlcndp
c2UsIHRoZSBDb2x1bW5WaWV3ZXJFZGl0b3Igd2lsbCBpbnN0YWxsIGFuIGFk ZGl0aW9uYWwg
Zm9jdXMgbGlzdGVuZXINCgkJCS8vIHRoYXQgY2FuY2VscyBjZWxsIGVkaXRp bmcgb24gZm9j
dXMgbG9zdCwgZXZlbiBpZiBmb2N1cyBnZXRzIGxvc3QgZHVlIHRvDQoJCQkv LyBhY3RpdmF0
aW9uIG9mIHRoZSBjb21wbGV0aW9uIHByb3Bvc2FsIHBvcHVwLiBTZWUgYWxz byBidWcgNTg3
NzcuDQoJCQlyZXR1cm4gZmFsc2U7DQoJCX0NCgl9DQoNCglwcml2YXRlIHN0 YXRpYyBjbGFz
cyBDb2xvck5hbWVFZGl0aW5nU3VwcG9ydCBleHRlbmRzIEVkaXRpbmdTdXBw b3J0IHsNCgkJ
cHJpdmF0ZSBUZXh0Q2VsbEVkaXRvcldpdGhDb250ZW50UHJvcG9zYWwgY2Vs bEVkaXRvcjsN
Cg0KCQlwdWJsaWMgQ29sb3JOYW1lRWRpdGluZ1N1cHBvcnQoVGFibGVWaWV3 ZXIgdmlld2Vy
KSB7DQoJCQlzdXBlcih2aWV3ZXIpOw0KDQoJCQlJQ29udGVudFByb3Bvc2Fs UHJvdmlkZXIg
Y29udGVudFByb3Bvc2FsUHJvdmlkZXIgPSBuZXcgU2ltcGxlQ29udGVudFBy b3Bvc2FsUHJv
dmlkZXIobmV3IFN0cmluZ1tdIHsgInJlZCIsDQoJCQkJCSJncmVlbiIsICJi bHVlIiB9KTsN
CgkJCWNlbGxFZGl0b3IgPSBuZXcgVGV4dENlbGxFZGl0b3JXaXRoQ29udGVu dFByb3Bvc2Fs
KHZpZXdlci5nZXRUYWJsZSgpLCBjb250ZW50UHJvcG9zYWxQcm92aWRlciwg bnVsbCwgbnVs
bCk7DQoJCX0NCg0KCQlAT3ZlcnJpZGUNCgkJcHJvdGVjdGVkIGJvb2xlYW4g Y2FuRWRpdChP
YmplY3QgZWxlbWVudCkgew0KCQkJcmV0dXJuIChlbGVtZW50IGluc3RhbmNl b2YgQ29sb3Ip
Ow0KCQl9DQoNCgkJQE92ZXJyaWRlDQoJCXByb3RlY3RlZCBDZWxsRWRpdG9y IGdldENlbGxF
ZGl0b3IoT2JqZWN0IGVsZW1lbnQpIHsNCgkJCXJldHVybiBjZWxsRWRpdG9y Ow0KCQl9DQoN
CgkJQE92ZXJyaWRlDQoJCXByb3RlY3RlZCBPYmplY3QgZ2V0VmFsdWUoT2Jq ZWN0IGVsZW1l
bnQpIHsNCgkJCXJldHVybiAoKENvbG9yKSBlbGVtZW50KS5uYW1lOw0KCQl9 DQoNCgkJQE92
ZXJyaWRlDQoJCXByb3RlY3RlZCB2b2lkIHNldFZhbHVlKE9iamVjdCBlbGVt ZW50LCBPYmpl
Y3QgdmFsdWUpIHsNCgkJCSgoQ29sb3IpIGVsZW1lbnQpLm5hbWUgPSB2YWx1 ZS50b1N0cmlu
ZygpOw0KCQkJZ2V0Vmlld2VyKCkudXBkYXRlKGVsZW1lbnQsIG51bGwpOw0K CQl9DQoNCgl9
DQoNCglwdWJsaWMgU25pcHBldFRleHRDZWxsRWRpdG9yV2l0aENvbnRlbnRQ cm9wb3NhbChT
aGVsbCBzaGVsbCkgew0KCQlmaW5hbCBUYWJsZVZpZXdlciB2aWV3ZXIgPSBu ZXcgVGFibGVW
aWV3ZXIoc2hlbGwsIFNXVC5CT1JERVIgfCBTV1QuRlVMTF9TRUxFQ1RJT04p Ow0KCQlmaW5h
bCBUYWJsZSB0YWJsZSA9IHZpZXdlci5nZXRUYWJsZSgpOw0KCQl0YWJsZS5z ZXRMaW5lc1Zp
c2libGUodHJ1ZSk7DQoJCXRhYmxlLnNldEhlYWRlclZpc2libGUodHJ1ZSk7 DQoNCgkJZmlu
YWwgVGFibGVWaWV3ZXJDb2x1bW4gY29sb3JDb2x1bW4gPSBuZXcgVGFibGVW aWV3ZXJDb2x1
bW4odmlld2VyLCBTV1QuTEVGVCk7DQoJCWNvbG9yQ29sdW1uLmdldENvbHVt bigpLnNldFRl
eHQoIkNvbG9yIG5hbWUiKTsNCgkJY29sb3JDb2x1bW4uZ2V0Q29sdW1uKCku c2V0V2lkdGgo
MjAwKTsNCgkJY29sb3JDb2x1bW4uc2V0TGFiZWxQcm92aWRlcihuZXcgQ29s dW1uTGFiZWxQ
cm92aWRlcigpKTsNCgkJY29sb3JDb2x1bW4uc2V0RWRpdGluZ1N1cHBvcnQo bmV3IENvbG9y
TmFtZUVkaXRpbmdTdXBwb3J0KHZpZXdlcikpOw0KDQoJCXZpZXdlci5zZXRD b250ZW50UHJv
dmlkZXIobmV3IEFycmF5Q29udGVudFByb3ZpZGVyKCkpOw0KDQoJCUNvbHVt blZpZXdlckVk
aXRvckFjdGl2YXRpb25TdHJhdGVneSBhY3RpdmF0aW9uU3VwcG9ydCA9IG5l dyBDb2x1bW5W
aWV3ZXJFZGl0b3JBY3RpdmF0aW9uU3RyYXRlZ3kodmlld2VyKSB7DQoJCQlA T3ZlcnJpZGUN
CgkJCXByb3RlY3RlZCBib29sZWFuIGlzRWRpdG9yQWN0aXZhdGlvbkV2ZW50 KENvbHVtblZp
ZXdlckVkaXRvckFjdGl2YXRpb25FdmVudCBldmVudCkgew0KCQkJCXJldHVy biBldmVudC5l
dmVudFR5cGUgPT0gQ29sdW1uVmlld2VyRWRpdG9yQWN0aXZhdGlvbkV2ZW50 LlRSQVZFUlNB
TA0KCQkJCQkJfHwgZXZlbnQuZXZlbnRUeXBlID09IENvbHVtblZpZXdlckVk aXRvckFjdGl2
YXRpb25FdmVudC5NT1VTRV9ET1VCTEVfQ0xJQ0tfU0VMRUNUSU9ODQoJCQkJ CQl8fCBldmVu
dC5ldmVudFR5cGUgPT0gQ29sdW1uVmlld2VyRWRpdG9yQWN0aXZhdGlvbkV2 ZW50LlBST0dS
QU1NQVRJQw0KCQkJCQkJfHwgKGV2ZW50LmV2ZW50VHlwZSA9PSBDb2x1bW5W aWV3ZXJFZGl0
b3JBY3RpdmF0aW9uRXZlbnQuS0VZX1BSRVNTRUQgJiYgZXZlbnQua2V5Q29k ZSA9PSBLZXlM
b29rdXBGYWN0b3J5DQoJCQkJCQkJCS5nZXREZWZhdWx0KCkuZm9ybWFsS2V5 TG9va3VwKElL
ZXlMb29rdXAuRU5URVJfTkFNRSkpOw0KCQkJfQ0KCQl9Ow0KCQlhY3RpdmF0 aW9uU3VwcG9y
dC5zZXRFbmFibGVFZGl0b3JBY3RpdmF0aW9uV2l0aEtleWJvYXJkKHRydWUp Ow0KDQoJCS8q
DQoJCSAqIFdpdGhvdXQgZm9jdXMgaGlnaGxpZ2h0ZXIsIGtleWJvYXJkIGV2 ZW50cyB3aWxs
IG5vdCBiZSBkZWxpdmVyZWQgdG8NCgkJICogQ29sdW1uVmlld2VyRWRpdG9y QWN0aXZhdGlv
blN0cmFnZXR5I2lzRWRpdG9yQWN0aXZhdGlvbkV2ZW50KC4uLikgKHNlZSBh Ym92ZSkNCgkJ
ICovDQoJCUZvY3VzQ2VsbEhpZ2hsaWdodGVyIGZvY3VzQ2VsbEhpZ2hsaWdo dGVyID0gbmV3
IEZvY3VzQ2VsbE93bmVyRHJhd0hpZ2hsaWdodGVyKHZpZXdlcik7DQoJCVRh YmxlVmlld2Vy
Rm9jdXNDZWxsTWFuYWdlciBmb2N1c0NlbGxNYW5hZ2VyID0gbmV3IFRhYmxl Vmlld2VyRm9j
dXNDZWxsTWFuYWdlcih2aWV3ZXIsIGZvY3VzQ2VsbEhpZ2hsaWdodGVyKTsN Cg0KCQlUYWJs
ZVZpZXdlckVkaXRvci5jcmVhdGUodmlld2VyLCBmb2N1c0NlbGxNYW5hZ2Vy LCBhY3RpdmF0
aW9uU3VwcG9ydCwgQ29sdW1uVmlld2VyRWRpdG9yLlRBQkJJTkdfVkVSVElD QUwNCgkJCQl8
IENvbHVtblZpZXdlckVkaXRvci5LRVlCT0FSRF9BQ1RJVkFUSU9OKTsNCg0K CQl2aWV3ZXIu
c2V0SW5wdXQoY3JlYXRlTW9kZWwoKSk7DQoJfQ0KDQoJcHJpdmF0ZSBDb2xv cltdIGNyZWF0
ZU1vZGVsKCkgew0KCQlyZXR1cm4gbmV3IENvbG9yW10geyBuZXcgQ29sb3Io InJlZCIpLCBu
ZXcgQ29sb3IoImdyZWVuIikgfTsNCgl9DQoNCgkvKioNCgkgKiBAcGFyYW0g YXJncw0KCSAq
Lw0KCXB1YmxpYyBzdGF0aWMgdm9pZCBtYWluKFN0cmluZ1tdIGFyZ3MpIHsN CgkJRGlzcGxh
eSBkaXNwbGF5ID0gbmV3IERpc3BsYXkoKTsNCg0KCQlTaGVsbCBzaGVsbCA9 IG5ldyBTaGVs
bChkaXNwbGF5KTsNCgkJc2hlbGwuc2V0TGF5b3V0KG5ldyBGaWxsTGF5b3V0 KCkpOw0KCQlu
ZXcgU25pcHBldFRleHRDZWxsRWRpdG9yV2l0aENvbnRlbnRQcm9wb3NhbChz aGVsbCk7DQoJ
CXNoZWxsLm9wZW4oKTsNCg0KCQl3aGlsZSAoIXNoZWxsLmlzRGlzcG9zZWQo KSkgew0KCQkJ
aWYgKCFkaXNwbGF5LnJlYWRBbmREaXNwYXRjaCgpKQ0KCQkJCWRpc3BsYXku c2xlZXAoKTsN
CgkJfQ0KDQoJCWRpc3BsYXkuZGlzcG9zZSgpOw0KCX0NCn0=
--------------060406090807050107080303--
Re: Table Text Cell Editor with Completion Proposals [message #331321 is a reply to message #331299] |
Mon, 01 September 2008 08:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Done. Filed as bug #245675
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=245675).
> Hi Mario,
> Great! Could you file a bug and attach the snippet else I'm not allowed
> to add it to CVS. CC'me on the bug and I'll incooperate it immediately.
> Please also include your Copyright in the header of the Snippet.
> Thanks for sharing your knowledge with us.
> Tom
>>> ContentProposal.
>>> Looks like:
>>> http://wiki.eclipse.org/JFaceSnippets#Snippet025TabEditing should be
>>> Tom
>>>>> have a simple Snippet we can upload to our collection?
>>>>> Tom
FUDForum. Page generated in 0.04295 seconds
