Which Adapters available? [message #331209] |
Thu, 28 August 2008 06:41  |
Hi there,
as I understand a common pattern used in Eclipse is the "Extensible
Objects" pattern: you can extend an existing class by adding adapters to it.
How can I find out what adapters are available for a certain class? To
find out what to do with a class, I usually look at the class API.
Obviously that's not enough to find out about its adapters, because the
meaning of adapters is to define them outside of the class. So how to
know where to look? And how to know if it's a good idea to use a certain
adapter as it might bring in new dependencies to those outside projects
where the adapter is defined...
Hauke
Re: Which Adapters available? [message #331213 is a reply to message #331209] |
Thu, 28 August 2008 09:15   |
--------------060103040709030506080400
Hauke,
I don't think you really can. The whole point of an adapter is to
provide something not provided by the base implementation. I suppose
the closest that comes to what you want is the registrations for the
|org.eclipse.core.runtime.adapters extension point.|
< http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html>
And yes, if you use some other API, you'll depend on (or at least load)
the plugins that provide it.
Hauke Fuhrmann wrote:
> Hi there,
> Cheers,
> Hauke
<html>
<head>
</head>
Hauke,<br>
<br>
the closest that comes to what you want is the registrations for the <code>org.eclipse.core.runtime.adapters
extension point.</code><a
href=" http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html"><br>
</a>
<blockquote><a
href=" http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html"> http://www.eclipse.org/articles/article.php?file=Article-Ada pters/index.html</a><br>
</blockquote>
the plugins that provide it.<br>
<br>
<br>
<blockquote cite="mid:g95vc2$gbi$1@build.eclipse.org" type="cite">
<pre wrap="">Hi there,
Hauke
</pre>
</blockquote>
</body>
</html>
--------------060103040709030506080400--
FUDForum. Page generated in 0.04557 seconds
