| InfoCenter Exception [message #331185] |
Wed, 27 August 2008 13:09   |
Eclipse User  |
we are using the eclipse infocenter deployed on tomcat to serve our
online help. Now we created an index from our docbook base and added it
to the plugin.xml as described in the eclipse help. So far so good, but
when we try to open the index we get this exception:
SCHWERWIEGEND: Servlet.service() for servlet equinoxbridgeservlet threw
exception
java.lang.ClassCastException: org.eclipse.help.internal.toc.Toc$1 cannot
be cast to org.eclipse.help.internal.Topic
        at org.eclipse.help.internal.toc.TocManager.getTopic
(TocManager.java:120)
        at org.eclipse.help.internal.index.IndexAssembler
$IndexComparator.getLabel(IndexAssembler.java:247)
$IndexComparator.compare(IndexAssembler.java:199)
        at java.util.Arrays.mergeSort(Arrays.java:1270)
        at java.util.Arrays.mergeSort(Arrays.java:1281)
        at java.util.Arrays.sort(Arrays.java:1210)
        at org.eclipse.help.internal.index.IndexAssembler.sort
(IndexAssembler.java:155)
(IndexAssembler.java:141)
        at org.eclipse.help.internal.index.IndexAssembler.assemble
(IndexAssembler.java:52)
        at org.eclipse.help.internal.index.IndexManager.getIndex
(IndexManager.java:59)
        at  org.eclipse.help.internal.webapp.servlet.IndexFragmentServle t
$Serializer.<init>(IndexFragmentServlet.java:125)
 org.eclipse.help.internal.webapp.servlet.IndexFragmentServle t.doGet
(IndexFragmentServlet.java:103)
        at  javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
        at  javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at org.eclipse.equinox.http.registry.internal.ServletManager
$ServletWrapper.service(ServletManager.java:180)
 org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest
(ServletRegistration.java:90)
 org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias
(ProxyServlet.java:111)
        at  org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce
(ProxyServlet.java:59)
        at org.eclipse.equinox.servletbridge.BridgeServlet.service
(BridgeServlet.java:121)
 org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter
(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter
(ApplicationFilterChain.java:206)
        at org.apache.catalina.core.StandardWrapperValve.invoke
(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke
(StandardContextValve.java:175)
        at org.apache.catalina.core.StandardHostValve.invoke
(StandardHostValve.java:128)
        at org.apache.catalina.valves.ErrorReportValve.invoke
(ErrorReportValve.java:102)
        at org.apache.catalina.core.StandardEngineValve.invoke
(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service
(CoyoteAdapter.java:286)
        at org.apache.coyote.http11.Http11Processor.process
(Http11Processor.java:844)
        at org.apache.coyote.http11.Http11Protocol
$Http11ConnectionHandler.process(Http11Protocol.java:583)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run
(JIoEndpoint.java:447)
        at java.lang.Thread.run(Thread.java:619)
Can anyone help us on how to resolve the issue?
We looked the the source of the TocManager which does the invalid cast.
And in fact the returned object, from the method call before the
exception is thrown, implements the interface ITopic but is not a Topic
object.
Thanks for any input
Markus Wolf
> emedia-solutions wolf    web: http://www.emedia-solutions-wolf.de
> Eimsbüttler Straße 115  mail: markus@emedia-solutions-wolf.de
> 22769 Hamburg            pgp: http://wwwkeys.de.pgp.net
> +49 40 432 635 83      taxid: 57 / 126 / 16123
| Re: InfoCenter Exception [message #331263 is a reply to message #331210] |
Thu, 28 August 2008 12:46   |
Eclipse User  |
This sounds like a bug, can you file a bug report. What is happening is
that an index entry in a remote toc does not have a label attribute and
it is trying to look up the href in the TOC, we have tested the remote
index but may not have hit on that particular situation in our testing.
Lee Anne wrote:
> Markus Wolf wrote:
>> it to the plugin.xml as described in the eclipse help. So far so good,
>> but when we try to open the index we get this exception:
>> threw exception
>> cannot be cast to org.eclipse.help.internal.Topic
>>         at
>>         at
>>         at
>>         at
>> cast. And in fact the returned object, from the method call before the
>> Topic object.
>> Markus Wolf
FUDForum. Page generated in 0.17943 seconds
