Eclipse 3.4 - 64 bit UI tests [message #331168] |
Wed, 27 August 2008 14:13 |
Jamie Grinstead![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jamigrin%40uk.ibm.com) Messages: 1 Registered: July 2009 |
Junior Member |
I'm not sure if this is the right place to ask about this. But I am having
a problem running the Eclipse 3.4 automated tests against 64 bit
platforms. On both Windows and Linux x86-64 when running antui, compare,
coreexpressions, jdtdebug, jdttext, jdtui, jdtuirefactoring,
ltkuirefactoring, pdeui, ua, uieditors, uinavigator, uiviews and
uiworkbenchtexteditor: none of the tests seem to run properly and exit
with this message Java Result: 13.
The other problem I am having is with OSGI tests and those that use OSGI
on Windows Server 2008 systems, and on any 64 bit system.
If anyone can help then please let me know.
FUDForum. Page generated in 0.03718 seconds
