Home » Eclipse Projects » Eclipse Platform » Eclipse 3.4 - 64 bit UI tests
Eclipse 3.4 - 64 bit UI tests [message #331168] Wed, 27 August 2008 10:13
I'm not sure if this is the right place to ask about this. But I am having
a problem running the Eclipse 3.4 automated tests against 64 bit
platforms. On both Windows and Linux x86-64 when running antui, compare,
coreexpressions, jdtdebug, jdttext, jdtui, jdtuirefactoring,
ltkuirefactoring, pdeui, ua, uieditors, uinavigator, uiviews and
uiworkbenchtexteditor: none of the tests seem to run properly and exit
with this message Java Result: 13.
The other problem I am having is with OSGI tests and those that use OSGI
on Windows Server 2008 systems, and on any 64 bit system.
If anyone can help then please let me know.
Previous Topic:Question on EFS (Eclipse File System) - EFS support on workspace projects
Next Topic:Hide a pop up item based on a system property?
Current Time: Sun Apr 27 02:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.02245 seconds
