Re: JFace Databinding + EMF + Performance [message #331145 is a reply to message #331144] |
Tue, 26 August 2008 17:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mario.winterer.gmx.net
Wow. Thanks for your quick response! You've just brought me to have a
closer look at jface databinding.
Sorry for the wrong newsgroup!
Tom Schindl schrieb:
> Hi Mario,
> This a general Databinding question which is better asked on the
> platform newsgroup but here's what I know:
> 1. Asynch-Updates:
> JFace Databinding has the concept of Realm which allows to do things out
> of the UI-Thread and sync back to the UI using Display#asyncExec().
> It also has the idea of a delaying and pooling changes (e.g. in
> SWTObservables#observeDelayedValue)
> 2. Not updateing invisible components:
> I think that when a control is hidden one could set its model to target
> startegy to UpdateValueStrategy.POLICY_NEVER (though it looks like this
> could not be changed after the binding is created) and calling
> binding.updateModelToTarget() once the element is shown at a later point
> in time.
> Tom
> Mario Winterer schrieb:
>> Hi!
>> We've written some kind of data binding framework for our (emf) model
>> objects long ago and now I'm wondering if it is possible to replace it
>> by the jface databinding framework step by step.
>> But I'm very concerned about the performance. Our framework makes use
>> of the Forms API's concept to refresh stale ui components only if they
>> are visible (that is if their form part is visible). Apart from that
>> we are able to delay the refreshing of certain form parts (using
>> Display.asnchExec) to collect all refresh requests in the meantime and
>> do one single refresh at the end. Without these concepts, our complex
>> model manipulations would result in an ui update stakkato with
>> horrible performance (especially because some operations might change
>> features more than once in one single model transaction)...
>> Are there any similar concepts in the JFace databinding framework,
>> especially in conjunction with emf?
>> I hope this is the correct newsgroup for this question...
>> Thanks,
>> Mario
FUDForum. Page generated in 0.02640 seconds
