Home » Modeling » GMF (Graphical Modeling Framework) » GMF mapping model problem... can't see all nodes & links (domain model elements)
GMF mapping model problem... can't see all nodes & links (domain model elements) [message #331141] Tue, 28 July 2009 02:55 Go to next message
Swapnil  is currently offline Swapnil Friend
I am using GMF Dashboard for creating a graphical editor.
When i create Mapping Model i can't see all the selected nodes & links
(domain model elements) from my Graphical Definition Model, i can see only
some of them.
Because of this i can't edit my Mapping Model as well manually as well.
Any hint regarding this problem?
Swapnil
Re: GMF mapping model problem... can't see all nodes & links (domain model elements) [message #353623 is a reply to message #331141] Tue, 28 July 2009 10:44 Go to previous message
Alexander Shatalin is currently offline Alexander ShatalinFriend
Hello Swapnil,
I suggest you create as much as it possible using dashboard and then openn
created .gmfmap file and directly edit it.
It's not so easy to duplicate complete .gmfmap editor logic in single wizard,
so gmfmap creation wizard definitely has some limitations now.
Alex Shatalin
Previous Topic:Kick start for multi page editor
Next Topic:Parameterized Actions?
Current Time: Fri Nov 08 23:37:24 GMT 2024
Powered by FUDForum. Page generated in 0.02975 seconds
