Re: Using Saxon 6.5 in Eclipse 3.4 [message #331140 is a reply to message #331127] |
Tue, 26 August 2008 15:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: subs._nospam_consertum.com
Jan Kohnert wrote:
> Hello,
> I want to write an plugin that uses Saxon 6.5 (for historical reasons)
> to perform XML transformations. That for I've includes saxon.jar into my
> plugin classpath and added the following VM argument inside my
> product.configuration file. (RCP App)
> -Djavax.xml.transform.TransformerFactory=com.icl.saxon.Trans formerFactoryImpl
> When creating the fransformer factory:
> TransformerFactory transFact = TransformerFactory.newInstance();
> I get a exception:
> java.lang.ClassCastException: com.icl.saxon.TransformerFactoryImpl
> cannot be cast to javax.xml.transform.TransformerFactory
> at javax.xml.transform.TransformerFactory.newInstance(Unknown Source)
> This it good for some point because it tells me that the system tries to
> use saxon, but bad for another because it does not work :(
> When trying:
> TransformerFactoryImpl transFact =
> (TransformerFactoryImpl)TransformerFactory.newInstance();
> I get the following exception:
> The 'normal' way is the first approach (TransformerFactory transFact =
> TransformerFactory.newInstance();). This one works perfectly fine when
> ever not beeing executed inside an eclipse plugin!
> Any suggestions regarding this strange behaviour?
> Thank,
> Jan
> This
Have you tried using a fully qualified name for TransformerFactory? It
looks like it is picking up a class of the same name from a different
package.
Derek
FUDForum. Page generated in 0.03520 seconds
