Home » Eclipse Projects » Eclipse Platform » How to participate in cut / copy / paste?
How to participate in cut / copy / paste? [message #331100] Mon, 25 August 2008 08:28 Go to next message
I want the cut / copy / paste buttons on the toolbar (and the Edit menu
options) to be enabled when user selects a view of my plugin. And I want
to perform some actions when the respective button is pressed. How can I
achieve this?
Thanks in advance.
Re: How to participate in cut / copy / paste? [message #331236 is a reply to message #331100] Thu, 28 August 2008 10:45 Go to previous messageGo to next message
kaprasanna wrote:
> achieve this?
Check out the help listed in my sig and
http://www.eclipse.org/articles/Article-action-contribution/ Contributing%20Actions%20to%20the%20Eclipse%20Workbench.html
PW
Paul Webster
Re: How to participate in cut / copy / paste? [message #331257 is a reply to message #331236] Thu, 28 August 2008 11:30 Go to previous messageGo to next message
Originally posted by: mario.winterer.gmx.net
Hi!
I think since eclipse 3.4 it should also be possible to use the command
framework and register a command handler for the required retargetable
action.
But I'm wondering what happens if both, an action delegate and a command
handler are registered for a given command/action id. What happens if
the command is executed? Will the handler be used or the action delegate?
Mario
Paul Webster schrieb:
> kaprasanna wrote:
>> menu options) to be enabled when user selects a view of my plugin. And
>> I want to perform some actions when the respective button is pressed.
>> How can I achieve this?
> PW
Re: How to participate in cut / copy / paste? [message #331276 is a reply to message #331257] Thu, 28 August 2008 13:56 Go to previous messageGo to next message
Mario Winterer wrote:
> Hi!
> action.
In 3.4 you can do it entirely using commands and handlers. For example,
when your view is created simply get the IHandlerService and register
handlers:
IHandlerService hs
= (IHandlerService) getSite().getService(IHandlerService.class);
hs.activeHandler("org.eclipse.ui.edit.copy", new MyCopyHandler());
// and so forth for cut and paste
PW
Paul Webster
Re: How to participate in cut / copy / paste? [message #331300 is a reply to message #331276] Fri, 29 August 2008 06:29 Go to previous messageGo to next message
Ah. Nice. I thought this is only possible using the extension point.
But in my case, a global action handler is already registered for the
copy action. Now I want to additionally register a handler for the same
copy action.
But unfortunately, the global action handler is chosen always, my
handler never gets executed.
>> Hi!
>> command framework and register a command handler for the required
>> retargetable action.
>> command handler are registered for a given command/action id. What
>> happens if the command is executed? Will the handler be used or the
>> action delegate?
> handlers:
> IHandlerService hs
> PW
Re: How to participate in cut / copy / paste? [message #331364 is a reply to message #331300] Wed, 03 September 2008 12:44 Go to previous messageGo to next message
> copy action.
The active handler gets determined by a (totally bogus) priority. The
default handler has a pri==0. The rest of the priorities are calculated
based on the activeWhen expression and the variables that they use (so
no activeWhen expression means pri==0).
The code example I showed you gets an ActivePartExpression on its way up
the chain, and so it has a higher priority than the default handler (and
works correctly as long as your part is active).
How are you registering your handler?
PW
Paul Webster
Re: How to participate in cut / copy / paste? [message #331412 is a reply to message #331236] Fri, 05 September 2008 03:01 Go to previous messageGo to next message
Hi Paul,
Looks like this is not working for me fully.
This is what I have done :
I am using Eclipse 3.3.2 (Europa).
I have used the extension point : org.eclipse.ui.handlers as :
<extension
point="org.eclipse.ui.handlers">
<handler
class="com.example.MyHandler"
commandId="com.example.handler">
<activeWhen>
<instanceof
value="com.example.helloworld.MyView">
</instanceof>
</activeWhen>
</handler>
</extension>
I have created a class MyHandler which extends
org.eclipse.core.commands.AbstractHandler.
This is the code in my view's createPartControl method :
IHandlerService hs =
(IHandlerService)getSite().getService(IHandlerService.class) ;
hs.activateHandler("org.eclipse.ui.edit.copy", new MyHandler());
I have a println statement in execute method of MyHandler as :
System.out.println("execute called...");
I run the project and click on my view.
The copy option on in Edit menu is not enabled.
But if I press ctrl+c. The above println comes up on the console.
Question : How do I enable the Edit -> copy / cut options when user clicks
on my view.
Thanks.
Re: How to participate in cut / copy / paste? [message #331423 is a reply to message #331412] Fri, 05 September 2008 08:15 Go to previous messageGo to next message
kaprasi wrote:
> Hi Paul,
> <extension
> <handler
> <activeWhen>
> <instanceof
> </instanceof>
> </activeWhen>
> </handler>
> </extension>
^^^ This definition is interesting, but has nothing to do with copy. On
top of that, the activeWhen clause will always be false (since the
default variable is a Collection).
This is fine, and what makes CTRL+C work.
> clicks on my view.
In 3.3 Edit>Copy is a RetargetAction. It will only enable if you also
have a
getViewSite().getActionBars().setGlobalActionHandler(ActionF actory.COPY.getId(),
new MyCopyAction());
You can make the handler and the action work off of the same code base
(so they're in sync).
In 3.4, the RetargetAction has been replaced with a
CommandContributionItem (which tracks the same state as CTRL+C)
PW
Paul Webster
Re: How to participate in cut / copy / paste? [message #331427 is a reply to message #331423] Fri, 05 September 2008 09:36 Go to previous messageGo to next message
Hi Paul,
Thanks for the reply.
I got it working. Now both ctrl+x / c / v as well as Edit->options work
fine.
But I still have a slight problem.
Because this code is being called from createPartControl() of the view, I
can't change these behaviors according to the selection.
To elaborate more :
The code in createPartControl() of the view looks like this :
Action copyAction = new Action() {
public void run() {
System.out.println("copied!!");
super.run();
IActionBars actionBars = getViewSite().getActionBars();
actionBars.setGlobalActionHandler(ActionFactory.COPY.getId() ,
copyAction);
// similar code for cut and paste
This enables cut / copy / paste options in Edit menu all-time;
irrespective of what is selected.
I want a control over when the edit menu options get enabled.
I have a method which gets called when a particular part of the view gets
selected. Placing the above code in that method doesn't work.
Thanks.
Re: How to participate in cut / copy / paste? [message #331450 is a reply to message #331427] Mon, 08 September 2008 08:09 Go to previous messageGo to next message
your code must call setEnabled(*) on your copyAction.
When your view is active, then Edit>Copy will be enabled depending on
your copyAction. When your view is not active, Edit>Copy is controlled
by some other part.
Later,
PW
Paul Webster
Re: How to participate in cut / copy / paste? [message #331471 is a reply to message #331450] Tue, 09 September 2008 03:03 Go to previous message
Paul,
It works fabulous.
Thanks so much.
Previous Topic:clipboard paste fails in eclipse 3.4.0
Next Topic:Get workbench's toolbar
Current Time: Sun Oct 26 14:10:23 EDT 2025
Powered by FUDForum. Page generated in 0.05442 seconds
