Home » Eclipse Projects » Eclipse Platform » Making IEditorPart Read Only
Making IEditorPart Read Only [message #331077] Sat, 23 August 2008 05:01 Go to next message
how to disable any editor given it's IEditorPart so that it's read only?
Yau.
Re: Making IEditorPart Read Only [message #331082 is a reply to message #331077] Sun, 24 August 2008 02:18 Go to previous messageGo to next message
The readonly behaviour is determined by whether the IEditorInput is
returning null or not for the getPersistable() method.
So override the method and return null.
- Prakash
www.eclipse-tips.com
Yau wrote:
> Yau.
Re: Making IEditorPart Read Only [message #331088 is a reply to message #331082] Sun, 24 August 2008 21:40 Go to previous messageGo to next message
thanks for your reply, but how about it's a third party editor, i.e. without
any control of the editor?
Yau.
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:g8quf6$695$1@build.eclipse.org...
> - Prakash
> Yau wrote:
> > Hi,
> > Yau.
Re: Making IEditorPart Read Only [message #331234 is a reply to message #331088] Thu, 28 August 2008 10:43 Go to previous messageGo to next message
For 3rd party editors, you would have to see if they allow you to set
them to read-only.
Aside from somehow making the incoming IEditorInput readonly (not sure
how, and it's probably not valid for all kinds of IEditorInput) there's
no framework way to say this is read-only.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Making IEditorPart Read Only [message #331297 is a reply to message #331234] Fri, 29 August 2008 05:31 Go to previous message
thanks for your reply, so "Eclipse's Activities" won't help?
Yau.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:g96drq$atp$2@build.eclipse.org...
> them to read-only.
> PW
> Paul Webster
Previous Topic:ILazyContentProvider updateElement(index) gets called for non-existent elements
Next Topic:Eclipse 3.4 on Windows XP Pro 64-bit
Current Time: Fri Apr 25 23:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.02953 seconds
