Home » Eclipse Projects » Eclipse Platform » Java Search Suggestion
Java Search Suggestion [message #331033] Thu, 21 August 2008 12:53 Go to next message
Using Ganemede --
The search menu provides some nice options for locating references,
declarations, implementors, read access and write access.
When the current selection is a class, it would be handy to have an option
to search for 'new' operations. For example, if I try to find all the
places that throw an exception, I search for references and get hundreds of
locations including throw and catch statements. It would really be handy if
the search could be reduced to throws.
Am I overlooking an option somewhere, or is this candidate for a feature
request?
Michael
Re: Java Search Suggestion [message #331036 is a reply to message #331033] Thu, 21 August 2008 14:33 Go to previous messageGo to next message
Moving to JDT tools.
Michael Giroux wrote:
> Using Ganemede --
> request?
> Michael
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Java Search Suggestion [message #331049 is a reply to message #331036] Fri, 22 August 2008 00:16 Go to previous messageGo to next message
I guess you are searching for the references of the class. Try searching
for the references of the constructor. You will find only the 'new'
operations. Only issue would be if there are multiple constructors, you
need to do multiple searches - one for each constructor.
- Prakash
www.eclipse-tips.com
>> Using Ganemede --
>> option to search for 'new' operations. For example, if I try to find
>> all the places that throw an exception, I search for references and
>> get hundreds of locations including throw and catch statements. It
>> would really be handy if the search could be reduced to throws.
>> feature request?
>> Michael
Re: Java Search Suggestion [message #331053 is a reply to message #331036] Fri, 22 August 2008 03:37 Go to previous messageGo to next message
>> Using Ganemede --
>> feature request?
To do fine-grained searches on a type open the Search dialog (Ctrl+H)
and then click on select 'Match locations' and configure them by
clicking on the link on the right.
Dani
>> Michael
Re: Java Search Suggestion [message #331187 is a reply to message #331053] Wed, 27 August 2008 13:50 Go to previous message
> To do fine-grained searches on a type open the Search dialog (Ctrl+H) and
> then click on select 'Match locations' and configure them by clicking on
> Dani
Excellent. A few more clicks but it gives the desired result.
Michael
Previous Topic:scanning for task for the tasks view.
Next Topic:Support for labelAttribute metadata
Current Time: Tue Apr 29 02:51:45 EDT 2025
Powered by FUDForum. Page generated in 0.07043 seconds
