Home » Eclipse Projects » Eclipse Platform » Ganymede JavaDoc Auto-Completion problems
Re: Ganymede JavaDoc Auto-Completion problems [message #331095 is a reply to message #331093] |
Mon, 25 August 2008 08:59 |
Bastian Preindl Messages: 4 Registered: July 2009 |
Junior Member |
some additional info (and most probably the root of all evil):
I've tested it on another machine, also Ganymede, but Mac OS 10.5.4.
Same behaviour. And it becomes even more odd:
A file, having a couple of private variables and public methods, has one
method looking like that:
public Bean executeMethod(HttpMethodBase method, Bean bean) throws
JobFinderException
method.setRequestHeader("Accept",
" text/xml,application/xml,application/xhtml+xml,text/html;q=0 .9,text/plain;q=0.8,image/png,*/*;q=0.5 ");
method.setRequestHeader("Accept-Language",
"de-de,de;q=0.8,en-us;q=0.5,en;q=0.3");
method.setRequestHeader("Accept-Encoding", "gzip,deflate");
method.setRequestHeader("Accept-Charset",
"ISO-8859-1,utf-8;q=0.7,*;q=0.7");
method.setRequestHeader("Keep-Alive", "300");
method.setRequestHeader("Connection", "keep-alive");
HttpClient client = new HttpClient();
Autocompletion does not work here. BUT when I remove the line
it works properly in the whole file.
Even if I just change the line to:
" text/xml,application/xml,application/xhtml+xml,text/html;q=0 .9,text/plain;q=0.8,image/png;q=0.5 ");
it works as it should. So the crux here is that the string "*/" is
obviously confusing the - apparently very simple - algorithm for
detecting comments (and their ends).
I guess this is indeed a bug in Ganymede - what do you think?
Bastian
Re: Ganymede JavaDoc Auto-Completion problems [message #331096 is a reply to message #331095] |
Mon, 25 August 2008 09:03 |
Dani Megert Messages: 3802 Registered: July 2009 |
Bastian Preindl wrote:
> one method looking like that:
> JobFinderException
I think that bugzilla is the right forum to report bugs ;-)
Dani
> Thanks
> Bastian
Current Time: Wed Sep 18 12:07:15 GMT 2024
Powered by FUDForum. Page generated in 0.02266 seconds
