Enabling or disabling command handler based on selection [message #330981] |
Wed, 20 August 2008 13:19 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nick.allen.onlinehome.de
I am writing a plug-in for Eclipse that integrates with the Bazaar
version control system. I have written my command handlers and used the
menu extension point to insert a "Bazaar" menu into the main eclipse
window. The problem is that my actions are always enabled and I need to
change that based on which files are selected or whether the editor has
focus or not. For selected files I need to check if they are in a parent
(or ancestor) directory that contains a ".bzr" directory and if the
editor has focus I need to check if the file being edited is in such a
directory structure.
The examples show how to use expressions in the XML file for the command
handlers but my condition is too complex to express in XML syntax. I
would like to do this programmatically or to at least write a new
expression class which I can then use in the XML (e.g.
IsUnderBazaarVersionControlExpression).
I have searched for 3 days solid and found nothing appropriate.
How do I do this? Any feedback greatly appreciated.
Many thanks in advance,
Nicholas Allen
Re: Enabling or disabling command handler based on selection [message #331022 is a reply to message #330981] |
Thu, 21 August 2008 14:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Does no-one know how to do this? I would really appreciate any help - I
am new to Eclipse and am getting frustrated that something so easy
should turn out to require so much work and investigation.
Nick
Nicholas Allen wrote:
> Nicholas Allen
Re: Enabling or disabling command handler based on selection [message #331028 is a reply to message #331027] |
Thu, 21 August 2008 15:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Many thanks for your replies! I will look into these - I hope it turns
out to be fairly easy...
Nick
Francis Upton (News) wrote:
> I don't know exactly, but have a look at org.eclipse.core.expressions,
> that shows you how to provide an expression programatically.
> Look at the command stuff in the Wiki as well. I always try to find an
> email by Paul Webster if I need to know about this stuff (it has the
> best links):
> Paul Webster
> http://wiki.eclipse.org/Platform_Command_Framework
> http://wiki.eclipse.org/Command_Core_Expressions
> http://wiki.eclipse.org/Menu_Contributions
> http://wiki.eclipse.org/Menus_Extension_Mapping
> http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
> You can create a Command programatically and associated an expression
> with it.
> HTH,
> Francis
>> Thanks,
>> Nick
>>> Hi,
>>> Nicholas Allen
FUDForum. Page generated in 0.02836 seconds
