Home » Eclipse Projects » Eclipse Platform » Error while updating RCP app through Eclipse Update Framework
Error while updating RCP app through Eclipse Update Framework [message #330974] Wed, 20 August 2008 03:52 Go to next message
Hi All...
My update action code is like...
public void run() {
BusyIndicator.showWhile(window.getShell().getDisplay(),
new Runnable(){
public void run() {
UpdateJob job = new UpdateJob("Searching for Updates", false, false);
UpdateManagerUI.openInstaller(window.getShell(), job);
and I am getting error like
"Errors while parsing update policy [The entity name must immediately
follow the '&' in the entity reference.]
The entity name must immediately follow the '&' in the entity reference.
the log entry...
!SESSION 2008-08-20 13:11:37.953
eclipse.buildId=unknown
java.version=1.5.0_09
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.core 4 0 2008-08-20 13:13:09.984
!MESSAGE Errors while parsing update policy [The entity name must
immediately follow the '&' in the entity reference.]
!STACK 0
org.xml.sax.SAXParseException: The entity name must immediately follow the
com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:264)
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:292)
org.eclipse.update.internal.search.UpdatePolicy.load(UpdateP olicy.java:122)
org.eclipse.update.internal.operations.UpdateUtils.loadUpdat ePolicy(UpdateUtils.java:534)
org.eclipse.update.search.UpdateSearchRequest.performSearch( UpdateSearchRequest.java:272)
at org.eclipse.update.ui.UpdateJob.runUpdates(UpdateJob.java:20 7)
at org.eclipse.update.ui.UpdateJob.run(UpdateJob.java:168)
What 'll be the fix?
-arun
Re: Error while updating RCP app through Eclipse Update Framework [message #330976 is a reply to message #330974] Wed, 20 August 2008 05:05 Go to previous messageGo to next message
I guess either your platform.xml or your your site.xml is not a well
formed XML. Can you check that?
- Prakash
www.eclipse-tips.com
Arunagiri wrote:
> Hi All...
> public void run() {
> new Runnable(){
> public void run() {
> job);
> the log entry...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> -arun
Re: Error while updating RCP app through Eclipse Update Framework [message #330980 is a reply to message #330976] Wed, 20 August 2008 07:08 Go to previous messageGo to next message
My site.xml is simple,
<site>
<category-def name="OMS" label="OMS Features"/>
<feature
url=" features/com.touchpoint.pharma.outlet.claims.feature_1.0.0.j ar "
id="com.touchpoint.pharma.outlet.claims.feature" version="1.0.0">
<category name="OMS"/>
</feature>
</site>
I don't know where is the errorrrr?
Arunagiri.K
Re: Error while updating RCP app through Eclipse Update Framework [message #331058 is a reply to message #330980] Fri, 22 August 2008 06:42 Go to previous message
Still I can't fix the error. The site.xml is created by the eclipse, and
it does not accepting external validations. As far as I know it's well
formed.
Any other crack?
-arun
Previous Topic:[Databinding] How to bind Tree that contains nodes with different types.
Next Topic:Writing to the Eclipse Log
Current Time: Tue Sep 16 09:49:36 EDT 2025
Powered by FUDForum. Page generated in 0.05250 seconds
