Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330969] |
Tue, 19 August 2008 19:59 |
Originally posted by: rami.muurimaki.gmail.com
I just "migrated" from Eclipse 3.3 to 3.4 (JEE). For some reason the
Open Type feature is not available. The short CTRL + SHIFT + T cut does
not work either. However Open Resource (CTRL + SHIFT + R) works perfectly.
Have I missed something or is this a bug or what?
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330970 is a reply to message #330969] |
Tue, 19 August 2008 20:14 |
rami kirjoitti:
seems like if I change the workspace location (create new one), the Open
Type is available again and it's working... I guess there is some broken
settings somewhere??
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330973 is a reply to message #330972] |
Wed, 20 August 2008 05:23 |
Emil Crumhorn kirjoitti:
> You probably want to clear out your metadata and start over so to speak,
> sounds like some old 3.3 metadata is conflicting with 3.4.
> (Or you can go in and re-assign Open Resource in the key binding section,
> although that might not be the only issue you run in to)
> Emil
> "rami" <rami.muurimaki@gmail.com> wrote in message
> news:g8f9k4$h3c$1@build.eclipse.org...
>> rami kirjoitti:
>>> I just "migrated" from Eclipse 3.3 to 3.4 (JEE). For some reason the Open
>>> Type feature is not available. The short CTRL + SHIFT + T cut does not
Maybe so or something else (bad) happened during the migration.
I think I've had the same .metadata folder from Eclipse version 3.1 :)
so I guess it's about the time to reconfig :)
Re: Navigate > Open Type is missing. Also CTRL + SHIFT + T does not work. [message #330986 is a reply to message #330969] |
Wed, 20 August 2008 15:16 |
What Perspective(s) did you try it in? Not all Perspectives are
configured to include the Open Type command (for example, Resources).
You can configure this via Window > Customize Perspective > Commands.
Hope this helps,
Eric
FUDForum. Page generated in 0.03092 seconds
