Re: Question about copy/paste behaviour on Linux [message #330959 is a reply to message #330958] |
Tue, 19 August 2008 15:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Francis Upton IV![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=francisu%40ieee.org) Messages: 472 Registered: July 2009 Location: Oakland, CA |
I just tried this and confirmed this to be the case on Fedora 9 with
Eclipse 3.4 (using both the Project Exporer and Package Explorer).
Oddly drag/drop works fine.
You should file a bug about this. Assign it to Platform/UI.
Andrew Mak wrote:
> I am wondering if this is a known limitation (or maybe bug?) with
> copy/paste behaviour on Linux...
> On windows, I can copy a file from eclipse's project explorer, and then
> paste it into an external app, such as Windows explorer. On Linux (I'm
> using RHEL5), after I copy the file, I cannot paste it into the file
> browser because the paste file action is always disabled (dragging a
> file from eclipse to the file browser works however).
> Andrew
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
FUDForum. Page generated in 0.03854 seconds
