Home » Eclipse Projects » Eclipse Platform » dependent plugins | plugin packaging
dependent plugins | plugin packaging [message #330874] Thu, 14 August 2008 16:26 Go to next message
Originally posted by: prasad.chand.gmail.com
I am trying to package a plugin as an rcp application. As a part of that
process I have created a product configuration file where I specify
the splash-screen and the icons (of various sizes).
When I test the product (by clicking the Launch eclipse app) it works
fine.But when I export the product and launch it as an application I am
facing the following two problems.
1. The icons and splashscreen are missing.
> I checked the config.ini its alright but splash.bmp and other icon
files are missing in the plugins/myplugin folder (though they are
present in my workspace when I exported the product).
2.unnecessary plugins are included in the exported application. How do I
just select just the dependent plugins of myplugin alone. I have seen
plug-in dependencies view but I am unable to "copy" them to the
configuration file.
Thanks in advance,
Prasad
Re: dependent plugins | plugin packaging [message #330927 is a reply to message #330874] Sun, 17 August 2008 13:25 Go to previous messageGo to next message
Originally posted by: cfondacci.free.fr
For you first problem, you simply have to tell the build to include the
files you need (typically your icons / image files).
You can do this by editing the build.properties file. You can then select
your resources to include form the "Build" tab (Binary build section) or
directly by editing the build.properties file through the corresponding tab.
Then reexport and your resources will be there.
For your 2nd point (dependencies), i am not quite sure what you need. You
have to select your plugin dependencies from the "Dependencies" tab of the
manifest editor of each of your plugin. Then if you have a product, you have
to select the whole set of plugins (or features) from the "Configuration"
tab of the product editor. This is what will be exported. It might be normal
to have "more" plugins exported than what you see in these views since your
dependent plugin may depend on other plugins which may be exported as well.
The button "Compute required plugins" is the one you need to automatically
detect which plugins should be exported with your application or product.
Hope this helps.
Christophe.
"Prasad Chand" <prasad.chand@gmail.com> a écrit dans le message de
news:g824dn$t0h$1@build.eclipse.org...
> process I have created a product configuration file where I specify the
> files are missing in the plugins/myplugin folder (though they are present
> configuration file.
> Thanks in advance,
> Prasad
Re: dependent plugins | plugin packaging [message #330940 is a reply to message #330927] Mon, 18 August 2008 11:58 Go to previous message
Christophe Fondacci wrote:
> Hello,
> select your resources to include form the "Build" tab (Binary build
> section) or directly by editing the build.properties file through the
> corresponding tab.
Thank you. I an now able to see the icons.
> You have to select your plugin dependencies from the "Dependencies" tab
> of the manifest editor of each of your plugin. Then if you have a
> product, you have to select the whole set of plugins (or features) from
> the "Configuration" tab of the product editor. This is what will be
> exported. It might be normal to have "more" plugins exported than what
> you see in these views since your dependent plugin may depend on other
> plugins which may be exported as well. The button "Compute required
> plugins" is the one you need to automatically detect which plugins
I had not taken into account the dependent plugins of plugins I
included. Thanks for your comments.
> Hope this helps.
> Christophe.
>> that process I have created a product configuration file where I
>> specify the splash-screen and the icons (of various sizes).
>> am facing the following two problems.
>> I just select just the dependent plugins of myplugin alone. I have
>> seen plug-in dependencies view but I am unable to "copy" them to the
>> configuration file.
>> Thanks in advance,
>> Prasad
Previous Topic:JFace ToolTip Accessibility
Next Topic:Create a plugin manually
Current Time: Mon Oct 27 14:27:16 EDT 2025
Powered by FUDForum. Page generated in 0.04018 seconds
