Home » Eclipse Projects » Eclipse Platform » what does "Referenced part does not exist yet" mean?
what does "Referenced part does not exist yet" mean? [message #330810] Wed, 13 August 2008 16:38 Go to next message
R3.3, WinXP
I get this log-entry three times at startup in our RCP:
!ENTRY org.eclipse.ui 4 4 2008-08-13 16:22:40.781
!MESSAGE Referenced part does not exist yet: com.mun.ist.MyViewsFolder.
The id refers to a layout-folder created in our IPerspectiveFactory,
like this:
public void createInitialLayout(IPageLayout layout) {
layout.setEditorAreaVisible(false);
layout.createFolder("com.mun.ist.MyViewsFolder", IPageLayout.BOTTOM,
0.5f, IPageLayout.ID_EDITOR_AREA);
The only other place where that ID is used is in our plugin.xml where
three views declare as follows:
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="com.mun.ist.our.perspective">
<view
closeable="true"
id="com.mun.ist.some.view"
moveable="true"
ratio="0.5"
relationship="stack"
relative="com.mun.ist.MyViewsFolder"
showTitle="true"
standalone="false"
visible="false">
</view>
</perspectiveExtension>
</extension>
What are we doing wrong? Or is that log-message just a warning and we
can ignore it?
thanks,
-Paul
Re: what does "Referenced part does not exist yet" mean? [message #330824 is a reply to message #330810] Thu, 14 August 2008 05:05 Go to previous messageGo to next message
Originally posted by: tom.seidel.spiritlink.de
Paul,
with
you're creating a folder with the id "com.mun.ist.MyViewsFolder".
You cannot reference this folder-id in the 'relative'-attribute of your
perspective extension. This attribute requires a view-id, not a folder-id
Tom
Paul Th. Keyser schrieb:
> R3.3, WinXP
> like this:
> <extension
> <view
> closeable="true"
> moveable="true"
> ratio="0.5"
> showTitle="true"
> standalone="false"
> visible="false">
> </view>
> </extension>
> can ignore it?
> thanks,
> -Paul
Re: what does "Referenced part does not exist yet" mean? [message #330841 is a reply to message #330824] Thu, 14 August 2008 09:28 Go to previous messageGo to next message
Tom Seidel wrote:
> Paul,
> with
> Tom
Ah -- I see. Can I use the id of the "editor area"? (I thought I tried
that and it failed.)
What we are trying to do is this:
| OurFixed | |
| View | Editor Area |
| |__________________________________|
| | Plugged-In Views |
| | Area/Folder |
Since the Views are plugged in, the IPerspectiveFactory of course cannot
know their ids.
Since the we want the Views located "down there", there is no way (that
I have thought of) to specify their location with respect to the
"OurFixedView".
Someone else tried the folder idea (which would work if we hard-wired in
the plugged-in views' ids, but ... bad plan).
thanks,
Paul
Re: what does "Referenced part does not exist yet" mean? [message #330894 is a reply to message #330824] Fri, 15 August 2008 11:22 Go to previous messageGo to next message
Tom Seidel wrote:
> Paul,
> with
Ah, so now I tried again setting that attribute to
"org.eclipse.ui.editorss" -- and it works! Is doing that an unreliable
kluge (since the id should be the id of a View) or is the docco slightly
wrong (and should say "of a View or of the editor-area")?
I find that the folder must exist, at least (I think my prior attempt to
use the id "org.eclipse.ui.editorss" failed b/c I also removed the folder).
thanks,
Paul
Re: what does "Referenced part does not exist yet" mean? [message #330935 is a reply to message #330894] Mon, 18 August 2008 10:28 Go to previous messageGo to next message
The second (org.eclipse.ui.editorss is valid as a relative ID for
perspective layouts).
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: what does "Referenced part does not exist yet" mean? [message #330956 is a reply to message #330935] Tue, 19 August 2008 10:03 Go to previous message
>> slightly wrong (and should say "of a View or of the editor-area")?
> PW
OK, thanks -- shall I enter a bug against Eclipse/ PDE/ Doc for the
ext.-pt. "org.eclipse.ui.perspectiveExtensions"?
-Paul
Previous Topic:Help regarding equinox p2
Next Topic:Question about copy/paste behaviour on Linux
Current Time: Wed Apr 16 05:06:54 EDT 2025
Powered by FUDForum. Page generated in 0.03469 seconds
