Re: Problem with eclipse head-less build [message #330808 is a reply to message #330802] |
Wed, 13 August 2008 20:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Andrew Niefer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aniefer%40gmail.com) Messages: 990 Registered: July 2009 |
The shape of the plug-ins are controlled by the containing feature.
In the feature editor, look on the Plug-ins tab, select an included
plug-in and uncheck "Unpack the plug-in archive after the installation".
In the feature.xml itself, this corresponds to the unpack attribute:
<plugin id="org.eclipse.equinox.launcher"
unpack="false"/>
If not specified, the default value for the unpack attribute is true,
which leads to folder shaped plug-ins. unpack="false" means keep the
plug-ins as jars.
-Andrew
Sri_know wrote:
> Hello All,
> I am trying to build a feature using eclipse head-less build system. The
> build works fine, but it is generating folders with plugin binaries in it,
> but I want it to create plug-in jars. I noticed that building a product is
> creating plug-in jars. Can any one help me in getting a solution to work
> with...
> thanks,
> Sridhar
FUDForum. Page generated in 0.03314 seconds
