egerrit dashboard stopped working [message #1746223] |
Tue, 25 October 2016 14:55 |
ran greenberg Messages: 4 Registered: January 2016 |
Junior Member |
hi
i have been working for a couple of month with the egerrit dashboard successfully. today i tried to connect to the server and got this error.
"An error occurred while contacting to server"
the log message is
Plug-in Version: 1.1.0.657
Gerrit server: https://rebaser/review
Version: 2.13.1.42
Transport error occurred GET https://rebaser/review/a/changes/?o=DETAILED_LABELS&o=CURRENT_REVISION&o=CURRENT_FILES&o=DETAILED_ACCOUNTS&o=CURRENT_COMMIT&o=REVIEWED&o=CURRENT_ACTIONS&q=is%3Aopen+AND+%28owner%3Aself+OR+reviewer%3Aself%29
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at line 1 column 3379
at org.eclipse.egerrit.internal.core.command.EMFTypeAdapterFactory$EObjectTypeAdapter.read(EMFTypeAdapterFactory.java:119)
at org.eclipse.egerrit.internal.core.command.EMFTypeAdapterFactory$EObjectTypeAdapter.read(EMFTypeAdapterFactory.java:1)
at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:40)
at com.google.gson.internal.bind.ArrayTypeAdapter.read(ArrayTypeAdapter.java:72)
at com.google.gson.Gson.fromJson(Gson.java:803)
at com.google.gson.Gson.fromJson(Gson.java:768)
at org.eclipse.egerrit.internal.core.command.BaseCommand$1.handleResponse(BaseCommand.java:149)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:218)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:160)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:136)
at org.eclipse.egerrit.internal.core.GerritHttpClient.execute(GerritHttpClient.java:171)
at org.eclipse.egerrit.internal.core.command.BaseCommand.call(BaseCommand.java:168)
at org.eclipse.egerrit.internal.core.command.QueryChangesCommand.call(QueryChangesCommand.java:101)
at org.eclipse.egerrit.internal.dashboard.ui.views.GerritTableView.performQuery(GerritTableView.java:1073)
at org.eclipse.egerrit.internal.dashboard.ui.views.GerritTableView.getReviewList(GerritTableView.java:1051)
at org.eclipse.egerrit.internal.dashboard.ui.views.GerritTableView.getReviews(GerritTableView.java:990)
at org.eclipse.egerrit.internal.dashboard.ui.views.GerritTableView.access$12(GerritTableView.java:965)
at org.eclipse.egerrit.internal.dashboard.ui.views.GerritTableView$11.run(GerritTableView.java:840)
Caused by: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at line 1 column 3379
When trying the GET https manually i get a file with all the gerrit data
i really like the egerrit dashboard hope there is a fix
thanks
FUDForum. Page generated in 0.03289 seconds
