Home » Eclipse Projects » Eclipse Platform » Create a plugin manually
Re: Create a plugin manually [message #330733 is a reply to message #330730] |
Tue, 12 August 2008 11:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33188 Registered: July 2009 |
--------------020008060106040302040906
Lukas,
It's also possible to just generate directly the textual artifacts that
make a Java project a plugin. The EMF generators do that to avoid
direct dependencies on the PDE. Here's some horrible code to look at
that creates either a plugin project or plain project. Files like the
plugin.xml and MANIFEST.MF are created textually based on JET templates.
public static IProject createEMFProject
(IPath javaSource,
URI projectLocationURI,
List<IProject> referencedProjects,
Monitor monitor,
int style,
List<?> pluginVariables)
IProgressMonitor progressMonitor =
BasicMonitor.toIProgressMonitor(monitor);
String projectName = javaSource.segment(0);
IProject project = null;
try
List<IClasspathEntry> classpathEntries = new
UniqueEList<IClasspathEntry>();
progressMonitor.beginTask("", 10);
progressMonitor.subTask
(CodeGenEcorePlugin.INSTANCE.getString
("_UI_CreatingEMFProject_message",
new Object [] { projectName, projectLocationURI !=
null ? projectLocationURI.toString() : projectName }));
IWorkspace workspace = ResourcesPlugin.getWorkspace();
project = workspace.getRoot().getProject(projectName);
// Clean up any old project information.
if (!project.exists())
URI location = projectLocationURI;
if (location == null)
location =
URI.createFileURI(workspace.getRoot().getLocation().append(p rojectName).toOSString());
location = location.appendSegment(".project");
File projectFile = new File(location.toString());
if (projectFile.exists())
projectFile.renameTo(new File(location.toString() +
".old"));
IJavaProject javaProject = JavaCore.create(project);
IProjectDescription projectDescription = null;
ResourcesPlugin.getWorkspace().newProjectDescription(project Name);
if (projectLocationURI != null)
projectDescription.setLocationURI(new
java.net.URI(projectLocationURI.toString()));
project.create(projectDescription, new
SubProgressMonitor(progressMonitor, 1));
project.open(new SubProgressMonitor(progressMonitor, 1));
else
projectDescription = project.getDescription();
if (project.hasNature(JavaCore.NATURE_ID))
classpathEntries.addAll(Arrays.asList(javaProject.getRawClas spath()));
boolean isInitiallyEmpty = classpathEntries.isEmpty();
if (referencedProjects.size() != 0 && (style &
(EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) == 0)
projectDescription.setReferencedProjects
(referencedProjects.toArray(new
IProject[referencedProjects.size()]));
for (IProject referencedProject : referencedProjects)
IClasspathEntry referencedProjectClasspathEntry =
JavaCore.newProjectEntry(referencedProject.getFullPath());
classpathEntries.add(referencedProjectClasspathEntry);
String [] natureIds = projectDescription.getNatureIds();
if (natureIds == null)
natureIds = new String [] { JavaCore.NATURE_ID,
"org.eclipse.pde.PluginNature" };
else
if (!project.hasNature(JavaCore.NATURE_ID))
String [] oldNatureIds = natureIds;
natureIds = new String [oldNatureIds.length + 1];
System.arraycopy(oldNatureIds, 0, natureIds, 0,
oldNatureIds.length);
natureIds[oldNatureIds.length] = JavaCore.NATURE_ID;
if (!project.hasNature("org.eclipse.pde.PluginNature"))
"org.eclipse.pde.PluginNature";
projectDescription.setNatureIds(natureIds);
ICommand [] builders = projectDescription.getBuildSpec();
if (builders == null)
builders = new ICommand [0];
boolean hasManifestBuilder = false;
boolean hasSchemaBuilder = false;
for (int i = 0; i < builders.length; ++i)
if
("org.eclipse.pde.ManifestBuilder".equals(builders[i].getBuilderName()))
hasManifestBuilder = true;
if
("org.eclipse.pde.SchemaBuilder".equals(builders[i].getBuilderName()))
hasSchemaBuilder = true;
if (!hasManifestBuilder)
ICommand [] oldBuilders = builders;
builders = new ICommand [oldBuilders.length + 1];
System.arraycopy(oldBuilders, 0, builders, 0,
oldBuilders.length);
builders[oldBuilders.length] =
projectDescription.newCommand();
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.ManifestBuilder ");
if (!hasSchemaBuilder)
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.SchemaBuilder ");
projectDescription.setBuildSpec(builders);
project.setDescription(projectDescription, new
IContainer sourceContainer = project;
if (javaSource.segmentCount() > 1)
IPath sourceContainerPath =
javaSource.removeFirstSegments(1).makeAbsolute();
sourceContainer = project.getFolder(sourceContainerPath);
if (!sourceContainer.exists())
for (int i = sourceContainerPath.segmentCount() - 1; i
>= 0; i--)
sourceContainer =
project.getFolder(sourceContainerPath.removeLastSegments(i)) ;
((IFolder)sourceContainer).create(false, true, new
IClasspathEntry sourceClasspathEntry =
JavaCore.newSourceEntry(javaSource);
for (Iterator<IClasspathEntry> i =
classpathEntries.iterator(); i.hasNext(); )
IClasspathEntry classpathEntry = i.next();
if (classpathEntry.getPath().isPrefixOf(javaSource))
i.remove();
classpathEntries.add(0, sourceClasspathEntry);
if (isInitiallyEmpty)
IClasspathEntry jreClasspathEntry =
JavaCore.newVariableEntry
(new Path(JavaRuntime.JRELIB_VARIABLE), new
Path(JavaRuntime.JRESRC_VARIABLE), new
Path(JavaRuntime.JRESRCROOT_VARIABLE));
if
(classpathEntry.getPath().isPrefixOf(jreClasspathEntry.getPa th()))
i.remove();
String jreContainer = JavaRuntime.JRE_CONTAINER;
String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);
if ("1.5".equals(complianceLevel))
jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J 2SE-1.5 ";
else if ("1.6".equals(complianceLevel))
jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J avaSE-1.6 ";
classpathEntries.add(JavaCore.newContainerEntry(new
Path(jreContainer)));
if ((style & EMF_EMPTY_PROJECT_STYLE) == 0)
if ((style & EMF_PLUGIN_PROJECT_STYLE) != 0)
Path("org.eclipse.pde.core.requiredPlugins")));
// Remove variables since the plugin.xml should
provide the complete path information.
if (classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_VARIABLE &&
!JavaRuntime.JRELIB_VARIABLE.equals(classpathEntry.getPath() .toString())
IClasspathEntry.CPE_PROJECT)
i.remove();
else
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries ,
"ECLIPSE_CORE_RUNTIME", "org.eclipse.core.runtime");
"ECLIPSE_CORE_RESOURCES", "org.eclipse.core.resources");
"EMF_COMMON", "org.eclipse.emf.common");
"EMF_ECORE", "org.eclipse.emf.ecore");
if ((style & EMF_XML_PROJECT_STYLE) != 0)
"EMF_ECORE_XMI", "org.eclipse.emf.ecore.xmi");
if ((style & EMF_MODEL_PROJECT_STYLE) == 0)
"EMF_EDIT", "org.eclipse.emf.edit");
if ((style & EMF_EDIT_PROJECT_STYLE) == 0)
"ECLIPSE_SWT", "org.eclipse.swt");
"ECLIPSE_JFACE", "org.eclipse.jface");
"ECLIPSE_UI_VIEWS", "org.eclipse.ui.views");
"ECLIPSE_UI_EDITORS", "org.eclipse.ui.editors");
"ECLIPSE_UI_IDE", "org.eclipse.ui.ide");
"ECLIPSE_UI_WORKBENCH", "org.eclipse.ui.workbench");
"EMF_COMMON_UI", "org.eclipse.emf.common.ui");
"EMF_EDIT_UI", "org.eclipse.emf.edit.ui");
if ((style & EMF_XML_PROJECT_STYLE) == 0)
if ((style & EMF_TESTS_PROJECT_STYLE) != 0)
"JUNIT", "org.junit");
if (pluginVariables != null)
for (Iterator<?> i = pluginVariables.iterator();
i.hasNext(); )
Object variable = i.next();
if (variable instanceof IClasspathEntry)
classpathEntries.add((IClasspathEntry)variable);
else if (variable instanceof String)
String pluginVariable = (String)variable;
String name;
String id;
int index = pluginVariable.indexOf("=");
if (index == -1)
name =
pluginVariable.replace('.','_').toUpperCase();
id = pluginVariable;
else
name = pluginVariable.substring(0, index);
id = pluginVariable.substring(index + 1);
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries , name, id);
javaProject.setRawClasspath
(classpathEntries.toArray(new
IClasspathEntry[classpathEntries.size()]),
javaProject.setOutputLocation(new Path("/" +
javaSource.segment(0) + "/bin"), new
catch (Exception exception)
exception.printStackTrace();
CodeGenEcorePlugin.INSTANCE.log(exception);
finally
progressMonitor.done();
return project;
Daniel Megert wrote:
> Lukas Witschi wrote:
>> Yes. The goal is to generate a serviceable plugin, which you can
>> import into eclipse.
> Take a look at the code in
> org.eclipse.pde.internal.ui.wizards.plugin.NewProjectCreatio nOperation
> Dani
>> -> Lukas
<html>
<head>
http-equiv="Content-Type">
</head>
Lukas,<br>
<br>
Ed Merks
Current Time: Sat Jul 27 13:26:38 GMT 2024
Powered by FUDForum. Page generated in 0.03315 seconds
