Home » Eclipse Projects » Eclipse Platform » Create new project wizard
Re: Create new project wizard [message #330690 is a reply to message #330675] |
Fri, 08 August 2008 13:26 |
Mark Melia Messages: 142 Registered: July 2009 |
Hi Rahul,
Thanks for your response, I think I sort of get it. I have done everything
in plugin.xml now, and have a wizard class which does the following in the
doFinish() method
private void doFinish(
String projectName,
IProgressMonitor monitor)
throws CoreException {
BasicNewProjectResourceWizard newProjectPage_ = new
BasicNewProjectResourceWizard();
newProjectPage_.init(this.workbench, null);
WizardDialog dialog = new WizardDialog(new Shell(Display.getDefault()),
newProjectPage_);
dialog.open();
but I get an error popup - "invalid thread access" - any idea what I am
doing wrong. Am I using the above code correctly?
Mark
Rahul Kamdar wrote:
> The article mentioned gives details with respect to the code of the wizard.
> You need to add an extension in your plugin.xml of type -
> org.eclipse.ui.newwizards and specify - category and wizard elements.
> Refer to:
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/dialogs_wizards_newWizards.htm
> and
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/reference/extension-points/org_eclipse_ui _newWizards.html
> (search for org.eclipse.ui.newwizards)
> Rahul
> "Mark Melia" <mark.melia@gmail.com> wrote in message
> news:a694e6ec314d450bdd4bd9d1b405e189$1@www.eclipse.org...
>> Hi all,
>> I want to great a new project wizard for my plugin, I assume I will have
>> to do something in plugin.xml and then possibly a listener which extends
>> the basic project wizard. Does anyone know how to do this? I found this
>> http://dev.eclipse.org/newslists/news.eclipse.tools/msg54739 .html on the
>> newsgroups but I dont really understand how Dan Armbrust, who posts the
>> query gets it to work?
>> Any ideas - thanks,
>> Mark
Re: Create new project wizard [message #330692 is a reply to message #330690] |
Fri, 08 August 2008 14:08 |
I found this code:
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IProject project = root.getProject(page.getName());
project.create(null);
project.open(null);
IProjectDescription description = project.getDescription();
String[] natures = description.getNatureIds();
String[] newNatures = new String[natures.length + 1];
System.arraycopy(natures, 0, newNatures, 0, natures.length);
//newNatures[natures.length] = JavaCore.NATURE_ID;
//description.setNatureIds(newNatures);
project.setDescription(description, null);
i stuck it into the dofinish method and hey presto i got my basic project
to create. I could be doing something horribly wrong so if you have any
feedback I would appriciate it.
Mark
Mark Melia wrote:
> Hi Rahul,
> doFinish() method
> String projectName,
> newProjectPage_);
> dialog.open();
> Mark
>> Refer to:
>> and
>> Rahul
>>> Hi all,
>>> Any ideas - thanks,
>>> Mark
Re: Create new project wizard [message #330701 is a reply to message #330690] |
Mon, 11 August 2008 00:50 |
Originally posted by: chingyichan.tw.gmail.com
Hi Mark,
Why do you create an instance of Wizard when finish? You can simply add
new WizardPage at the addPages callback. Using IWizardPage is easier
then Dialog.
Mark Melia 提到:
> Hi Rahul,
> everything in plugin.xml now, and have a wizard class which does the
> following in the doFinish() method
> String projectName,
> Shell(Display.getDefault()), newProjectPage_);
> dialog.open();
> Mark
>> wizard.
>> Refer to:
>> and
>> Rahul
>>> Hi all,
>>> have to do something in plugin.xml and then possibly a listener which
>>> extends the basic project wizard. Does anyone know how to do this? I
>>> found this
>>> the newsgroups but I dont really understand how Dan Armbrust, who
>>> posts the query gets it to work?
>>> Any ideas - thanks,
>>> Mark
Re: Create new project wizard [message #330702 is a reply to message #330692] |
Mon, 11 August 2008 00:52 |
I have a method for creating java project. Maybe it will help you.
private IJavaProject createJavaProject(IProject project) throws
CoreException,
JavaModelException {
IProjectDescription desc = project.getDescription();
desc.setNatureIds(new String[] { JavaCore.NATURE_ID });
project.setDescription(desc, null);
IJavaProject javaProject = JavaCore.create(project);
IFolder binDir = project.getFolder("bin");
IPath binPath = binDir.getFullPath();
javaProject.setOutputLocation(binPath, null);
Set<IClasspathEntry> entries = new HashSet<IClasspathEntry>();
entries.add(JavaRuntime.getDefaultJREContainerEntry());
javaProject.setRawClasspath(entries
.toArray(new IClasspathEntry[entries.size()]), null);
return javaProject;
Mark Melia 提到:
> Hi
> I found this code:
> project.open(null);
> project to create. I could be doing something horribly wrong so if you
> have any feedback I would appriciate it.
> Mark
> Mark Melia wrote:
>> Hi Rahul,
>> String projectName,
>> dialog.open();
>> am doing wrong. Am I using the above code correctly?
>> Thanks,
>> Mark
>>> wizard.
>>> Refer to:
>>> and
>>> Rahul
>>>> Hi all,
>>>> which extends the basic project wizard. Does anyone know how to do
>>>> this? I found this
>>>> Any ideas - thanks,
>>>> Mark
Re: Create new project wizard [message #330729 is a reply to message #330692] |
Tue, 12 August 2008 09:09 |
Rahul Kamdar Messages: 63 Registered: July 2009 |
Member |
Hi Mark,
Sorry for a late response.
I agree with Chan - why are you using the dialog? You could use the
WizardPage for whatever you wish to do. The invalid thread access is
probably due to the access to UI components from a non-UI thread. In case
you want to do anything with eclipse UI, it's a good practice to invoke it
in the Eclipse UI thread using the
PlatformUI.getWorkbench().getDisplay().syncExec/asyncExec (Runnable {public
void run () {your code here}}).
What do you need to do exactly? Just create a plain new project or do some
configuration/processing after that is done? Try describing your problem if
possible.
Rahul
news:c2851aa485b1aafc7d8da546a7badf70$1@www.eclipse.org...
> Hi
> I found this code:
> project.open(null);
> Mark
> Mark Melia wrote:
>> Hi Rahul,
>> String projectName,
>> newProjectPage_);
>> dialog.open();
>> Thanks,
>> Mark
>>> wizard.
>>> Refer to:
>>> and
>>> Rahul
>>>> Hi all,
>>>> found this
>>>> the newsgroups but I dont really understand how Dan Armbrust, who posts
>>>> Any ideas - thanks,
>>>> Mark
Current Time: Sat Jul 27 18:40:54 GMT 2024
Powered by FUDForum. Page generated in 0.03594 seconds
