Home » Eclipse Projects » Eclipse Platform » Some very very strange thing about the open action in the CNF?
Some very very strange thing about the open action in the CNF? [message #330657] |
Thu, 07 August 2008 15:55 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I extend the ProjectExplorer, and maped some file to my elements.
To open that elements, I added an actionProvider in the navigatorContent
extension.
In my actionProvider class I called the
actionBars.setGlobalActionHandler(ICommonActionConstants.OPE N, myAction);
The run() in my action just called the IDE.openEditor() method.
The strange thing is that, for some editors (infact which extends the
EditPart directly) , there can by one instance of that kind of editor,
for example, there is AEditor which is used to open the files like *.a
and BEditor which is used to open the files like *.b.
if i opened an AEditor, the if I double-click on the elements that will
open BEditor, nothing happen.
And, if I add a break-point in the run method, if I double-click, it
always will be arrive to the break-point in the run method.
That is to say, with the break-point, the run method will always be excuted.
but if I remove the break-point, the run method will not excuted(it can
be konw throug the System.out.printl("****")).
But if I right-click on the element B, and select "Open" in the context
menu, It works well.
This had made me crazy, hope that there is some one can help me.
Dollyn
Re: Some very very strange thing about the open action in the CNF? [message #330658 is a reply to message #330657] |
Thu, 07 August 2008 16:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Addtional,
If I opened an AEditor, then if I double-click on some B elements,
nothing will happen.
But I switch to another window, in windows xp, and switch back, and then
B elements, BEditor will open.
This message maybe help.
Dollyn 写道:
> extension.
Dollyn
Re: Some very very strange thing about the open action in the CNF? [message #330698 is a reply to message #330658] |
Sun, 10 August 2008 05:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Shawn Spiars![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=sspiars%40abac.com) Messages: 16 Registered: July 2009 |
Junior Member |
Dollyn,
It's hard to determine what you problem is without seeing the code,
I had a similar problem recently and I resolved it by overriding the
handleDoubleClick method in my class which extends the CommonNavigator.
Shawn
Dollyn wrote:
> Addtional,
> Dollyn 写道:
>> extension.
>> excuted.
Re: Some very very strange thing about the open action in the CNF? [message #330704 is a reply to message #330698] |
Mon, 11 August 2008 08:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Well, I replaced the method IDE.openEditor(page, file); to
IDE.openEditor(page, file, false);
and everyting seams ok now.
In the JavaDoc of this method, the description about the third parameter
is: "If |activate == true| the editor will be activated. "
I'm not sure about the meanning of the "activated" here, because my
editor always "getFocus", although I give it a "false".
Shawn Spiars wrote:
> Dollyn,
> Shawn
> Dollyn wrote:
>> Addtional,
>> then double-click on some
>> Dollyn
Dollyn
Current Time: Wed Jul 17 10:31:35 GMT 2024
Powered by FUDForum. Page generated in 0.03212 seconds
