Home » Eclipse Projects » Eclipse Platform » Defining help contexts
Defining help contexts [message #330648] Thu, 07 August 2008 05:32 Go to next message
I've made a plugin that declares a class extending StatusDialog, and
inherits the help button in the lower-left corner. How can I attach my
help context to it?
In plugin.xml I've got this:
<extension point="org.eclipse.help.contexts">
<contexts file="helpContexts.xml"/>
</extension>
and in helpContexts.xml I've got this:
<contexts>
<context id="mydialog_contextid">
<description>Here's my description.</description>
<topic href="html/stuff.html" label="A help topic"/>
</context>
</contexts>
I've tried overriding the protected createDialogArea method:
protected Control createDialogArea(Composite parent) {
IWorkbench workbench = PlatformUI.getWorkbench();
workbench.getHelpSystem().setHelp(parent, "mydialog_contextid");
Except then when I press the help button it says "The context help for
this user interface element could not be found." (Without the code I put
in createDialogArea it just says the default "Each workbench window
contains one or more ...", so it is doing something...)
Tom
Re: Defining help contexts [message #330782 is a reply to message #330648] Wed, 13 August 2008 09:14 Go to previous messageGo to next message
> help context to it?
> </extension>
> <contexts>
> </context>
> </contexts>
I think you need to call setHelp() passing the Control that is returned
from createDialogArea() instead of the parent argument. Like this:
Hope this helps,
Eric
Re: Defining help contexts [message #330799 is a reply to message #330782] Wed, 13 August 2008 12:27 Go to previous messageGo to next message
Then I get the default message about workbench windows, and not my help
context. :-/
Tom
Re: Defining help contexts [message #330833 is a reply to message #330799] Thu, 14 August 2008 09:20 Go to previous message
> context. :-/
It seems to depend on what control has focus when the Help button is
clicked. In our dialogs I call setHelp() for the result of
DialogPage.getControl() AND the Control that is returned from
createDialogControl(), and that seems to work regardless of where the
user clicks (or doesn't click) before clicking the ? button.
Hope this helps,
Eric
Previous Topic:How do I add a preferences page programatically at run time?
Next Topic:Sorting table Viewer
Current Time: Fri Apr 25 00:50:02 EDT 2025
Powered by FUDForum. Page generated in 0.02612 seconds
