Home » Eclipse Projects » Eclipse Platform » RE: Access file in developed plugin
RE: Access file in developed plugin [message #330639] Wed, 06 August 2008 13:35 Go to next message
Hi all,
I have a little problem. I have developed a plugin, and in my plugin in
have an XML properties file. I need to be able to access this properties
file in my plugin code - to do this i need the file location. Does anyone
know how to do this?
Thanks for your help,
Mark
Re: Access file in developed plugin [message #330651 is a reply to message #330639] Thu, 07 August 2008 06:30 Go to previous messageGo to next message
Hi all,
I found this post
http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.platfo rm/msg32261.html
, which outlines how to access a file in a plugin at runtime using an
InputStream. What I am trying to do is to define a build file and embed
that in the plugin and then call the ant programmatically using the
AntRunner. Unfortunately the AntRunner doesnt seem to work with an
InputStream representation of the build file - so does anyone know how to
either allow AntRunner to accept an InputStream as its buildfile (instead
of the file location) or know how to specify a file location for the build
file which is in the plugin jar at runtime?
Mark
Mark Melia wrote:
> Hi all,
> Mark
Re: Access file in developed plugin [message #330699 is a reply to message #330651] Sun, 10 August 2008 01:39 Go to previous message
Mark,
Maybe this method will help.
public static Properties getPropertiesFromPlugin(
String fileName, String pluginId) {
Properties properties = new Properties();
try {
Path path = new Path(fileName);
Bundle bundle = Platform.getBundle(pluginId);
InputStream propStream = FileLocator.openStream(bundle, path, false);
properties.load(propStream);
propStream.close();
} catch (IOException e) {
return properties;
Shawn
Phurnace Software
Mark Melia wrote:
> Hi all,
> I found this post
> to either allow AntRunner to accept an InputStream as its buildfile
> (instead of the file location) or know how to specify a file location
> for the build file which is in the plugin jar at runtime?
> Mark
> Mark Melia wrote:
>> Hi all,
>> in have an XML properties file. I need to be able to access this
>> properties file in my plugin code - to do this i need the file
>> location. Does anyone know how to do this?
>> Mark
Previous Topic:Purpose of default value for extension attribute
Next Topic:how to change editor font size
Current Time: Fri Oct 24 08:36:05 EDT 2025
Powered by FUDForum. Page generated in 0.04941 seconds
