Home » Eclipse Projects » Eclipse Platform » Trouble with Jobs after multiple calls to PlatformUI.createAndRunWorkbench
Trouble with Jobs after multiple calls to PlatformUI.createAndRunWorkbench [message #330625] Tue, 05 August 2008 19:37 Go to next message
My application uses a TrayIcon which is wrapped around the call to
PlatformUI.createAndRunWorkbench(). When the user choose to Exit the
application (from File->Exit, which is the IWorkbenchAction from the
ActionFactory), I call Display.readAndDispatch() until the MenuItems for
Open or Exit on the TrayIcon are pressed. If Open is pressed then i
call PlatformUI.createAndRunWorkbench() again.
One key point is that I create a new Display from PlatformUI and use a
new WorkbenchAdvisor each time PlatformUI.createAndRunWorkbench(),
otherwise more issues arise.
The only problem i am experiencing is with my Jobs on subsequent
createAndRunWorkbench() calls .. while they do execute correctly, they
do not appear in the ProgressView, nor do they display progress
information in a dialog.
Does anyone have insight onto calling PlatformUI.createAndRunWorkbench()
multiple times? Or a better way to hide the workbench with the ability
to retrieve it from a Tray Icon?
I have noted that the ProgressManager object is the same through both
launches of the Workbench.
Gary
Re: Trouble with Jobs after multiple calls to PlatformUI.createAndRunWorkbench [message #330793 is a reply to message #330625] Wed, 13 August 2008 10:07 Go to previous message
Originally posted by: tom.seidel.spiritlink.de
When you want to implement a tray icon, that shows up, if the user
closes the window you can override the preWindowShellClose() in your
WorkbenchWindowAdvisor:
public boolean preWindowShellClose() {
final boolean[] res = new boolean[] { true };
this.fMinimizeFromClose = true;
getWindowConfigurer().getWindow().getShell().notifyListeners (SWT.Iconify,
new Event());
res[0] = false;
this.fMinimizeFromClose = false;
return res[0];
Tom
> Gary
Previous Topic:Best way of removing data from a virtual TableViewer
Next Topic:Open files from shell
Current Time: Fri Oct 31 09:10:27 EDT 2025
Powered by FUDForum. Page generated in 0.03683 seconds
