Home » Eclipse Projects » Eclipse Platform » passing view reference into actions
passing view reference into actions [message #330600] Tue, 05 August 2008 05:39 Go to next message
Originally posted by: marc.esher.comcast.net
Greetings all. I've got a view. it has a panel with a Tree in it. I have an
action that does stuff to the tree.
My question is simple: is it appropriate to pass the view reference into the
action so that the action can get the tree and operate on it? Or is there
some other, more preferred way?
Here's actual code I'm using.
From my view:
public void makeActions(){
toggleTreeItemsAction = new ToggleTreeItemsAction(this); // Pass the view
into the action's constructor
toggleTreeItemsAction.setText("Expand/Collapse All");
toggleTreeItemsAction.setToolTipText("Expand/Collapse all Tree Items
(Ctrl-+)");
toggleTreeItemsAction.setImageDescriptor(
ResourceManager.getImageDescriptor(ResourceManager.EXPANDCOL LAPSEALL)
Then, the Action:
public final class ToggleTreeItemsAction extends Action {
private MyView view;
public ToggleTreeItemsAction(MyView view){
this.view = view;
public void run(){
//view.getTestsViewer() returns the tree in the view
if(view.getTestsViewer().getVisibleExpandedElements().length ==0){
view.getTestsViewer().expandAll();
}else{
view.getTestsViewer().collapseAll();
Thanks for any input!
marc
Re: passing view reference into actions [message #330861 is a reply to message #330600] Thu, 14 August 2008 13:35 Go to previous messageGo to next message
That is one of the most common ways to use your own actions, simply
create them in the view part itself.
If your actions are limited to the view part and you don't need
keybindings, that should work fine.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: passing view reference into actions [message #331004 is a reply to message #330861] Wed, 20 August 2008 21:13 Go to previous messageGo to next message
thanks for responding, Paul.
If I'm not creating actions in the view itself as inner classes, is there a
preferred way for accessing the view in the manner I've described?
thanks!
marc
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:g81qln$shn$2@build.eclipse.org...
> That is one of the most common ways to use your own actions, simply create
> PW
> Paul Webster
Re: passing view reference into actions [message #331153 is a reply to message #331004] Tue, 26 August 2008 14:21 Go to previous messageGo to next message
> there a preferred way for accessing the view in the manner I've described?
For commands and implementations of AbstractHandler, the currently
active part can be retrieved using HandlerUtil static methods.
Then you can check to see if it is your IViewPart.
PW
Paul Webster
Re: passing view reference into actions [message #331155 is a reply to message #331153] Tue, 26 August 2008 17:35 Go to previous message
Cool. thanks Paul.
news:g91hss$3oq$2@build.eclipse.org...
> For commands and implementations of AbstractHandler, the currently active
> PW
> Paul Webster
Previous Topic:FocusListener on Section
Next Topic:Using Saxon 6.5 in Eclipse 3.4
Current Time: Tue Apr 29 05:09:59 EDT 2025
Powered by FUDForum. Page generated in 0.04469 seconds
