Home » Language IDEs » C / C++ IDE (CDT) » stdout not shown?
stdout not shown? [message #33482] Wed, 22 May 2002 11:34 Go to next message
Originally posted by: jason.379.com
A stupid question maybe? The CDT docs state that stdout, stdin,
and stderr will be shown on the console view during debugging.
That doesn't seem to be the case, for me at least, all I get
is a blank window there.
Should this feature be working at this point? I didn't see
anything in bugzilla.
Specs: Eclipse M5, CDT R2-20020508, RH Linux 7.3, JDK 1.4.
Thanks for the assistance (again!)
Jason
Re: stdout not shown? [message #33550 is a reply to message #33482] Wed, 22 May 2002 13:41 Go to previous messageGo to next message
Hi Jason,
Work for displaying output and getting input to debugee is still in
progress.
Stdin is not working yet. Stdout and Stderr can be found in GDB Console.
To get to the GDB Console, go to Window->Show View->Other... Under Debug,
you will find GDB Console.
GDB Console is intended for user to interact with GDB directly. If you
type in a GDB command in that console, you will see output resulted from
that command displayed in that window. In addition to that, you will see
program output and GDB responses in GDB Console when your program is
running.
Hope this helps.
Samantha
> Jason
Re: stdout not shown? [message #33584 is a reply to message #33550] Wed, 22 May 2002 13:45 Go to previous message
Also, there is a Bug opened for this work:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=11963
Samantha
Samantha Chan wrote:
> Hi Jason,
> progress.
> running.
> Hope this helps.
> Samantha
> > Jason
Previous Topic:Exception on debug app?
Next Topic:Integration of automake and autoconf requirement specs doc is now available!
Current Time: Fri Nov 07 07:17:59 EST 2025
Powered by FUDForum. Page generated in 0.03335 seconds
